Re: What happened to the Bedan???
Don Evans
Well I'm afraid I don't agree! The bedan is like any woodturning tool, it's a matter of knowing how to use it. I find it nothing like a skew as far as grabbing etc.
So what is the difference here between me and John? It's that I was shown how to use one by the master himself that John mentioned ( I am not sure how to spell his name either John) Escoulen?
Anyway, here is a quick lesson:
You must raise the tool rest higher than you normally do, to set it, lay the tool on the wood with the bevel UP, then hold the tool horizontally as level as you can and raise the tool rest up to the tool. This set up is most important to how the tool will work.
To make a planning cut that is as good or better than a skew twist the tool slightly ccw so the left corner is touching wood on top of wood angle to handle to the right slightly and move the tool left cutting with just the left corner. The right side of the front edge will only be raised off the wood maybe 1/64 to 1/32". To plane to the right just reverse above. You'll soon be doing beads same way by not moving left but just twisting the tool and not angling the handle to right (or left) depending on what side of bead you are doing.
This is a very easy tool to use when done properly.
One really important thing also is when cutting down the diameter of a rounded piece like making a tenon on the end for a chuck do NOT use the full width of the cutting end. Use only about 1/3 of the width of the tool.
Now I have no financial stake in this, but there is a big difference in the tool that Jean sells and the others on the market. It is forged similiar to a Japanese sword with folded metal over folded metal to make it. I have one from him and another from another popular tool company and there is no comparison. I reach for the Escoulen ever time.
As someone already said, DO NOT GRIND on this tool to sharpen it, just touch it up with a fine grit diamond file, I use a 1200 grit, I think, it is an EZE Lap with the red handle.
There is also an advantage to putting a very short bevel on the opposite side of the edge from the bevel but it is hard to put in words how it should be done. But it is about 1/16" long from front edge going back toward the handle and is only 1 or 2 degrees.
There is no advantage to a wide Bedan so if you can get the one that Escoulen sells that is 1/4" wide or slightly wider.
Don
