grinding wheel replacement
richie c
So I'm wondering, at what diameter should you change a 6 inch grinder wheel for safety sake as it wears down?
richie c
Re: grinding wheel replacement
The only real reason to worry about that would be if you are using a jig and don't readjust it as the wheel gets smaller. This might move the grind closer to the center of the wheel and for safety sake you always need to grind above center.
I've used wheels down to 5" with no problems although the convex portion gets steeper which in theory could weaken your edge but I didn't have any problems.
That is why I changed to 8" wheels however. I could get a lot more life out the wheel but in reality my sharpening techniques have improved to the point that my wheels now last a long time.
richie c
thanks John, I'm already down to 4 & 1/2".I think I'll replace wheel. Hope my grinding skills improve. I enjoy your you tube videos.There really helpful!
robo hippy
Do look into the CBN wheels. They do come in 6 inch diameter. Really worth every penny, and they don't wear out or change size.
robo hippy
Brad Vietje
Keep in mind that as the diameter gets smaller, the "hollow" of the hollow grind gets more and more pronounced. This added concavity makes your tool edges more fragile, more grabby, more aggressive, and, unless you are honing them extensively to develop flats at the edge and heel, you're losing bevel contact while scraping more and cutting less on concave surfaces like bowls and vases...
If you greatly magnify the cutting edge interacting with the spinning wood in your mind's eye -- or sketch it on paper -- you can see that a smaller wheel can be a disadvantage over a larger wheel (or sometimes a flat, or even convex bevel surface).
I think an 8" CBN wheel would be a good thing, but pretty pricy. Just food for thought.
thank you brad
