Why I wear gloves rough turning
Dale Bonertz
I was reminded yesterday afternoon why I wear a glove on my right hand when rough turning. I was rough turning box elder, maple and hack berry. Most of the rounds had some bark on them if not the entire outside. Cruising along to finish these 13 rounds when I mounted a maple round. Checked the bark like I do on all rounds and it was holding tight so I will turn it off. After I made a couple of slices a piece of bark came loose about the size of my thumb or slightly larger. Now most of the time they fly of without much interest but this one came off just at the right moment and right angle to smack me square into the end of my thumb (underhand grip). I am happy to report that it stung a bit and made me take my glove off to make sure there was no damage. All was well after giving my hand a couple of air shakes. If I would have been using an overhand grip (perfectly acceptable) it would have smacked me on the back of my hand. I can't be sure but looking at the piece of bark there were some sharper edges that may have cut me if I wasn't wearing the glove, causing more damage than would have been necessary.
This all got me thinking once again about safety measures. The glove, although deemed unsafe by some (and can be if not paying attention), I feel saved my thumb from further damage. Then it occurred to me that those that rough turn right handed and stand closer to and sometimes in the line of fire could catch one of these small pieces in the face or neck if they are not wearing a face shield. That would really sting and maybe cause a small cut or bruise.
Just wanted to share with you all to be safe out there. Most of the time what we do nothing eventful happens. But that one time it does I hope you are wearing protective gear to minimize damage.
Re: Why I wear gloves rough turning
ron bauer
Dale, I hear what you are saying about safety and the need for constant diligence. One needs to always consider what might go wrong. I recently had an experience with gloves while drilling holes with the drill press. I was wearing those abrasion resistant gloves that have been dipped in a rubber compound. I really like them. As I was relocating the work piece my right middle finger contacted the turning drill. Well, in less than a millisecond my finger was grabbed by the drill, twisted 180 degrees, and held against the turning drill. The immediate damage was a VERY nasty cut on the inside of the finger as the flutes chewed on the meat. The lasting damage was a probable tearing or at least stretching of the ligaments to the point that I can't fully tighten my grip with that finger any more. I will never wear those rubber gloves around something that has the chance of grabbing them. I do believe in gloves, but they need to be the right ones for the job.
i couldn't agree more
Dale Bonertz
Not only the right type of glove but sometimes for certain applications no gloves are the answer. Glad to hear your accident did not turn out worse.
Jesper, Denmark
Jesper, Denmark
The modern types of mechanics' gloves, which are designed to allow you to handle small parts with the gloves on seem to be a suitable compromise. They are comfortable and fit tigthly, so no loose flaps to catch on a spinning object.
I am firmly in the "don't wear floppy workgloves" camp, but feel quite safe and comfortable with the tight ones.
robo hippy
I do turn bowl blanks that still have some bark on them. Maybe it is another advantage of using scrapers for roughing. I always start in the center bottom of the bowl, and nibble my way out to the rim, then down the side. When I used gouges for this roughing, I did have some pieces of bark that bounced off my tools, the wall and ceiling, and my tool rest. With scrapers, I can stand at the end and push straight down the side of the bowl where the bark is, and my hands are out of the line of fire.
http://www.youtube.com/watch?v=hKdqiAc0jx4
robo hippy
You touch on an important misconception
Dale Bonertz
The line of fire is not limited to straight off the piece as many would have you believe. As you a slicing the wood a piece of bark or chunk of wood can lift off the piece and ricochet off the tool, tool rest or the piece itself. Some of the energy is absorbed by whatever it ricocheted off of but it still can hurt like ****. The line of fire, in my opinion, is more of a conical shape from the piece. When I am production rough turning I have little bits pinging me on the face shield all the time. Some have suggested that I am presenting the tool wrong or this or that but the truth is they a bits coming off the piece (most likely bark or those tiny bark included areas your turning off) that are ricocheting off of the piece, tool and tool rest. They for the most part are harmless but wearing a glove and face shield sure alleviates the sting and or minor cuts they would cause otherwise.
Make no mistake I think the main line of fire that people really get disfigured, killed or severely hurt by is that straight line from the piece. However you can still get hurt by the pieces coming in the conical fire zone also.
Re: You touch on an important misconception
robo hippy
That is a point I try to remember when giving bowl turning demos, and preaching my 'standing out of the line of fire' sermon.
I did used to have a 'bowl turner's callus' on my left pinky finger. Seemed that no matter what I did when using a gouge for roughing, the shavings would go right across that little finger. Worse with dry wood. Still happened with an underhanded grip. I never used gloves though. Now that callus is gone. Part of why I like scrapers.
robo hippy
