Honey Locust ~PIC~
Honey Locust ~PIC~
Honey Locust ~PIC~
Wes Pilley
Last weekend I was given a couple large pieces of Honey Locust. I was finally able to spin it and find out what was hid inside this big piece of wood. The tree was half dead.
[URL=http://smg.photobucket.com/user/Powderkeg3418/media/Wood%20turnings/Honeylocust001_zps638163a4.jpg.html][/URL]
I cut the log in half and marked how I was going to cut it up.
[URL=http://smg.photobucket.com/user/Powderkeg3418/media/Wood%20turnings/Honeylocust002_zpsed646ca1.jpg.html][/URL]
I then trimmed up the corners a little with my chainsaw.
[URL=http://smg.photobucket.com/user/Powderkeg3418/media/Wood%20turnings/Honeylocust003_zpsa6e09f8e.jpg.html][/URL]
[URL=http://smg.photobucket.com/user/Powderkeg3418/media/Wood%20turnings/Honeylocust004_zps74e81607.jpg.html][/URL]
A friend of mine has a big homemade lathe. I took the chunk over to his place to turn it. Here it is set up between centers.
[URL=http://smg.photobucket.com/user/Powderkeg3418/media/Wood%20turnings/Honeylocust005_zps13760c94.jpg.html][/URL]
There was kind of a flat spot on one side. That made the bowl a little shallower than I had planned.
[URL=http://smg.photobucket.com/user/Powderkeg3418/media/Wood%20turnings/Honeylocust006_zps47da1d06.jpg.html][/URL]
A lot of the time the shape of the log will determine the shape of the bowl. I was careful to leave the piece as big as I could. Once I got to this size I started refining the shape a little.
[URL=http://smg.photobucket.com/user/Powderkeg3418/media/Wood%20turnings/Honeylocust007_zpsd83a501b.jpg.html][/URL]
Once I got it looking good I added a couple beads. They make it look pretty nice.
[URL=http://smg.photobucket.com/user/Powderkeg3418/media/Wood%20turnings/Honeylocust008_zpsb2556663.jpg.html][/URL]
I then turned it around and scooped out the inside. I'll post pictures of the finished bowl tomorrow. I ran out of light today. It ended up being 14 1/2" in diameter.
Thanks for watching:o)
~Wes~
Re: Honey Locust ~PIC~
Lloyd in Mississauga
Very nice looking piece, and the beads do seem to help.
Your foot seems a bit small for that shaped side. With the broad slope will the piece be easily tipped over? If the sides have a steeper slope then a smaller foot may be ok as the contents will tend to roll to the bottom of the bowl. With this one, the broad sides may not force the contents into the center and hence be a bit tippy.
Re: Honey Locust
Wes Pilley
This is a biggish bowl. The base is 5" in diameter. It doesn't seem very tippy. I was a little concerned about that. The next one I will make a female dovetail to hold onto when I turn it around. This will let me make the base a little bigger.
Thanks for the input:o)
~Wes~
Re: Honey Locust
Dale Bonertz
Nice bowl Wes. If you use the rule of thirds your 5 inch base is plenty. A 14" bowl times 33% gives you roughly 4 1/2".
You appear to be a experienced turner by the form and beads you put on this bowl. Honey locust is so pretty but hard as nails when dry. I have dried quite a bit of honey locust so I will give you one caveat. The sap wood you left on the bowl is very pretty but take care drying it. The sap wood likes to check on honey locust but the heart wood usually is pretty tolerant. Nicely done.
Dale
Re: Honey Locust
Wes Pilley
Thanks! I have been turning wood for a year or so. Everything I do seems to be an experiment. Take this bowl for example. I put the walnut oil on pretty thick to help slow down the drying and limit the checking.
~Wes~
Re: Honey Locust ~MORE PIC~
Wes Pilley
Thanks for the compliments!
Here is the finished bowl.
[URL=http://smg.photobucket.com/user/Powderkeg3418/media/Wood%20turnings/Honeylocust009_zps63035ac2.jpg.html][/URL]
[URL=http://smg.photobucket.com/user/Powderkeg3418/media/Wood%20turnings/Honeylocust010_zps9b357bbe.jpg.html][/URL]
[URL=http://smg.photobucket.com/user/Powderkeg3418/media/Wood%20turnings/Honeylocust011_zps3305c394.jpg.html][/URL]
I am trying to work my way through this Honey locust. I have a few pieces left. I did manage a few smaller bowls and a 13" platter. The big bowl here is 10 1/2" in diameter.
[URL=http://smg.photobucket.com/user/Powderkeg3418/media/Wood%20turnings/Honeylocust012_zps8b5b3fa4.jpg.html][/URL]
This sure is pretty wood:o)
[URL=http://smg.photobucket.com/user/Powderkeg3418/media/Wood%20turnings/Honeylocust013_zps5544eee5.jpg.html][/URL]
~Wes~
Jim Breeden
Beautiful pieces Wes! I've turned some honey locust - dry - hard as concrete, :b , but worth it.
