Skew Sharpening
Stuart Johnson
What is the difference in handling and preferred angle (heel to toe) when sharpening a skew?
Skew Sharpening
Stuart Johnson
Re: Skew Sharpening
Greg Haugen
In general there's two methods of sharpening a skew; straight and radius/Lacer/Raffan. As a general rule the angle from heel to toe in either case is 70 degrees. The straight is just that, straight 70 degrees and the radius grinds the actual toe and heel are still at the 70 degree mark but the "belly" of the radius is curved out over the straight line. The 70 degree is a starting point and the general rule. Minor tweaks to that angle is just fine. The technicality for the Lacer skew is the top third (toe) is straight and then the bottom (heel) is radiused. That straight section is used for the peeling cut. Also as a general rule, the bevel is one and a half times the thickness of the steel. 1/4" steel, roughly 3/8" of a bevel. I like mine just slightly shorter than that. Some go by an angle degree but it usually still falls within that range.
As to what is preferred? Coke or Pepsi, Ford or Chevy; it's personal preference and the right one is the one you use and learn with. I like them both and have both grinds. I like a straight on my 1/2" skew and a radius on my 1" skew. My radius though is more of a Raffan skew. Just a radius, no straight section.
Grind it on the grinder and then HONE on a diamond hone or a wet stone.
Re: Skew Sharpening
Here's a couple of videos that may answer your question. In reality it doesn't matter. It's all personal preference. I like a concave grind sharpened with diamond hones or sanding belt with an included angle or about 35 degrees. I like the edge to be straight back by about 30 degrees or so. Here a couple of videos that might help.
http://www.youtube.com/watch?v=YFlZyGKYro4
