When I need a longer lathe,
Keith Newton
Dang, I meant to take a pic while I had the finished newell on it, but forgot. I'm restoring a porch on a victorian home up the street, and needed a couple of Newell post ~ 54" tall, which exceeds the length of my old PM 45.
When I built my big bowl lathe, I used the same height off the floor, so when I need something longer, I can set the PM up in line with axis of the other, then by turning the tailstock around, can get support on out as far as I feel comfortable with.
I'm sure others have done this, up thought I would share this, just in case some of you dual lathe owners ever needed to add this trick to your bag.
Re: When I need a longer lathe,
Guy Bratt
I saw someone on Youtube do this with of all things a pair of shopsmiths. One end secured to a structural post. They turned a rather large diameter log near the length of both units.
I did that when I had my Nova 3000 and Nova comet mini lathe. I turned the tailstock around on the mini and then clamped the 2 lathes together with a 2x4. Made a long tool rest out of some hardwood I had.
One time I had to turn a platter larger than my lathe would swing. I moved the headstock out to the end of the bed and took the Banjo and tool rest and clamped it to my floor standing drill press table.
If you really really want to do something, you'll figure out a way.
Steve Kubien
Kinda, sorta
Steve Kubien
There's a video out there somewhere of Nick Cook putting two 3520's together to turn a monster tree trunk for a table.
Re: Kinda, sorta
Bernie Rose
This rick can also be achieved by bolting the tailstock of a Shopsmith to the wall and screwing the rest of it to the floor at the appropriate distance.
Mike Foster
There is a turner in our club who was asked to duplicate a couple of columns for a town hall in VT. Pretty long spindles (20 ft or so). His solution was way more Jerry rigged than yours. He uses a Shopsmith to turn with an put this 20 ft away from a wall, braced the shopmith well, put a dead center into a post in his post and beam barn/shop at the right height then turned a 20 ft spindle with a freestanding tool rest. It worked. Looked a bit scary to me, but hey he's still kicking.
John lucas
Boy that would have scared me. I had a shop smith. The lathe is probably the weakest tool on that machine. However noe that I think about it the tailstock and tool rest are the weakest link and be didnt use those
