Photo tutorial put up on photo forum
Re: Photo tutorial put up on photo forum
Thanks, John
Let me ask you a couple questions that may be relevant here...
1. Do digital cameras have the film equivalent of reciprocity failure, that is, if the light is very low and the exposure long, does it affect the appearance of the image? Can you get around this by shooting in RAW mode?
2. Can you approximate the fidelity of 5,000K light by doing a custom white balance in the camera?
3. How the heck *do* you shoot glossy pieces?
4. If you can afford strobes, is that a better way to go?
#3Re: Thanks, John
I'll put this answer on both forum's.
Not that I have been able to tell. I did a test on this one day because we did a lot of long exposures on campus for different things. I could not tell it when doing exposures up to a minute. You do get more snow and odd artifacts the longer you go. With the lights I'm using, which are pretty weak, my exposures never run over about 5 or 10 seconds and usually far shorter.
Shooting in Raw helps a lot when you have to correct the image later. I can't tell that it changes anything in terms of long exposures. It simply gives you enough data so you can use other tools in photoshop or other programs to get rid of artifacts and snow.
Yes. If your camera has that capability.
Write me for my article on shooting really glossy pieces. It is quite difficult and I go into it extensively. You can use any or all of the techniques depending on how far you want to go. I shot a lot of glass, silver jewelry, and glossy ceramics. The Walnut piece I photographed for the article was really challenging
It takes a really really powerful strobe (electronic flash is the better word) to give you maximum depth of field. Shooting something such as a deep bowl it can take f22 or even 32 if you have it to even get close to getting everything sharp. It can take a 3200 watt second flash to give you that kind of power especially when you shoot through a panel or softbox which eats up more power. They are not cheap. You can fire 1weaker flash multiple times if you have a totally dark room and very steady camera stand. I've shot cave interiors with 1 small flash unit where I had to fire it as many as 50 times to cover the big walls. It's much easier in the same dark room to simply leave the shutter open for long periods of time and use these inexpensive continuous lights.
#4Re: Very Helpful
Steve Criscenzo
John
Thanks for the article. It clears some things up for me. I notice your grey background is on a roll. Is there a reason you need a roll rather than a single piece. Is it special photo background or just grey paper.
Thanks again
Steve
#5The closest equivalent to reciprocity ....
JamieDonaldson
....failure in the digital domain is the "push" to higher ISO's on digicams. Higher ISO's begin to display artifacts as John mentioned, but I don't recall ever reading about extended low ISO/long exposures causing any equivalent to reciprocity failure? There are now software plug-ins that can diminish the random artifacts of high speed capture, and this application continues to evolve as special application software improves. Of course digital capture is still not up to the dynamic range of exposure latitude that we had with some film materials such as color negative film, but way better than the early latitude ranges of image chips!
#6Re: Very Helpful
It is a 4 foot by 12 yard roll of photo paper. At least it started that way. I cut it down to 20" to fit my panels. This is a leftover piece. I use the larger background for larger work. When it gets down to about 6 or 8 feet left I cut it down to fit my smaller table top work.
You can get the background paper from www.porters.com
#7Looks like Porters web store is closed.
#8Re: Looks like Porters web store is closed.
Bummer. You can buy Seamless photo paper at almost any major photo store. B@H photo is another good source.
#9Backdrop roll *LINK*
Mike Brazeau
If you have ever lived in an old house, you may have a old window blind kicking around. I cut one down to about 24" wide and painted with some medium gray paint I mixed up from ceiling white and a few drops of black acrylic craft paint. It is fasten to a length of 1/2" dowell and makes the back unit of my frame made up of dowels and homemade corners. Corners are short lengths of 2x2 with holes in appropriate places, with some dowels glued in and some loose to store.
The Joy of Wood
Excellent answers. Thanks!
#11Re: Backdrop roll
I had very poor luck with window blinds. They show a curl from being rolled up. Perhaps you have different blinds. I know Jamie Donaldson has use one but all the ones I tried all had a sort of curl set that would show up in the photos.
#12a good place to get backgrounds *LINK*
http://www.adorama.com/catalog.tpl?op=itemlist&cat1=Flash/Lighting&cat2=Backgrounds%20%26%20Background%20Support%20Equipment&cat3=Seamless%20Paper
