for some free plans for segment TS sled. I would like it to adjustable for cut angle. I have found two that have fixed cut angles of 15 degrees. I am just starting with segmenting so I am more comfortable that being able to adjust for cut angle.
Re: I have looked in our archives and else where..
John lucas
I'm out of town so I can't send you a photo Maybe you can do a search for John Lucas miter gauge or segment sled or some such. Mine is fully adjustable and very repeatable once you get it set
Alan Sweet
Thanks, John. I found a photo from a forum log on AAW. , and I understand most it. I see why you say it is fully adjustable. Looks like it would work for me. Is there a write up on it? If not I just start asking questions. (and I never run out of questions.)
John lucas
It has a micro adjuster for fine tuning. It has two brass pins so once you find the perfect angle by trial and error you measure the gap with dial calipers a d I can the. Reset that distance to within a fe thousandths.
It also has a t slot cut in the fence to adjust and lock the out feed distance stop and angle
Here is another detail shot of my sled. You can see the two brass pins that I can measure between to re set it accurately. It would be fairly easy to do a test at 0 and 45 and then divide these evenly to get marks to put on the cut out arc to get you close to certain degrees. However what I intend to do in the long run is to tests for each of the more common settings, 4, 8, 12, 16, 24, and 32 and then write down the measurements so I can exactly duplicate these cuts. The back short fence locks down and the knob micro adjusts the front fence for sneaking up on the dead on angle or distance. Then both fences are locked down for the actual cut.
I like a sled that rides in both miter slots. It simply has less slop for more accuracy. The angled jig on the right of the blade is adjustable for angle and has a T slot cut in the fence for resetting the distance from the blade for different size segments. Then angle helps support the segment.
The one thing my jig lacks is a lock down to hold each segment. I'm working on that. right now I simply use a pencil with the eraser down. I hold it during the cut and then when I slide the jig back I can slide each segment out and to the right. Works pretty efficiently which is why I haven't spent any time working on a more elaborate hold down system. I'll be glad to shoot some more photos if anyone needs them.
in angle is multiplied when segments are cut. That is, a small error made 32 times (for a 16-sided segmentted ring) is significant in the final glue up. Adjusting for this is fiddly.
I have made the sled referenced in the link above in multiple editions. I.e. a 6 sided ring, 8 sided ring, 12-sided ring etc. The initial calibration IS time consuming but then the fence is screwed down to the base and it is good forever. I just take the appropriate sled down from the shelf, cut the segments, glue up and I have a perfect ring every time.
Take the time to make a dedicated sled for each number of segments in a ring. You will save an enormous amount of time in the long run by not having to constantly make test cuts and adjust...adjust...re-adjust....you get the idea.
I don't have room to store multiple sleds that's why I designed mine so the adjustable part can be re set to within a few thousandth of an inch 16 inches from the pivot point.
Forget about the thousands. Get the segments close enough and put the glued up half circles to the disk sander to make the ends square so the circle will be round.
Bernie that works for many segmented turnings but it can affect how some designs line up because you are actually making a slight ellipse instead of a true circle. So ideally you should shoot for a perfect glue up of one circle instead of 2 half rings.
Touche John. But if you have a segment within a couple of thousands, and the segments are open on the perimeter before sanding by the time you have cut off the projections to make the segment round ( after gluing up the whole vessel ) the point of the actual circle will be dead center. This assumes you have cut the segments big enough to compensate for any out of round discrepancy of the individual segments, and the open part of the half circle is on the outisde, not on the inside.
