200+ woodworking book reviews
Finish help and blank help?
Earl
I gave a biscuit cutter to a neighbor and she started using it and showing it to friends. Well I really wasn't expecting her to use it and I used a wiping polly on it. Now she wants a set 3 like my wife has. What would be a good finish and still have some shine to it keeping in mind she may be using it to cut biscuit's. I thought mineral oil then bees wax?
I happened to see a neighbor had a stack of wood that he was going to burn. I asked if I could cut some for myself and he said yes. There was some very nice pecan wood in the pile. Everything I have is just cut off the log. Do I need to split it and take the pith out? If so how much do I need to take out of the middle? I have sealed the ends. Is pecan bad about splitting? Thanks For Any Help Earl
Re: Finish help and blank help?
john Veerkamp
Earl, Anything used in actually preparing food will NOT stay shinny. I just use oil (Mahoney's ) on my salad bowls, biscuit cutters, rolling pins. Can be easily renewed as the wood starts to dry.
Pecan is a very nice, hard as nails (pecancrete) . It will split from the pith out fairly quickly as it dries.
uesable area is from the pith out to the bark. Keep your tools sharp!
John Leonard
I use General Salad Bowl Finish (GSBF) on my biscuit cutters and don't have had no issues with it staying shiny. Pecan is great. I have heard dry pecan called pecancret but with sharp tools never had a problem with it. It looks great with GSBF. John L.
Brad Vietje
Brad Vietje
I'm with you, John V... I'll even go a little further and state that I do not want any wood touching my food to be shiny.
I think a good utilitarian oil finish is fine, and shiny wood in my view is not necessary or even desired. Just my personal opinion, for whatever it's worth. Mahoney's Utility Finish or Tried & True Original will work well, and many people making spoons, spatulas and other treen have used a simple oil finish.
BTW: "mineral oil" is made from petroleum, so even though we've all grown up with and around it, I'm no fan of using petroleum products in my food, either, so I won't use it for this sort of purpose. There are many nut and seed oils that will work fine, and some are non-toxic right out of the can or bottle, though most will not be shiny.
Safe spinning,
Brad Vietje
Newbury, VT
