Tinting wood glues?
Tinting wood glues?
Tinting wood glues?
ron bauer
Does anyone have experience with coloring or tinting any of the traditional wood glues? I'm thinking black, red, green. What type of dye did you use? TIA. Ron.
Re: Tinting wood glues?
Alan Sweet
Alan Sweet
No I have not tried that, but you have my curiosity up and I do have a couple applications if it works. Thanks for bringing it up.
I'll do some experimentation. You have any suggestions to start with.
ron bauer
Alan, I have only vague ideas at this point. I am not enough of a chemist to know what might work. I have even considered, as a last resort (LOL), calling a manufacturer and asking their thoughts. Would aniline work? Food coloring? What effect might it have on the bond strength? Ron.
Remember that aniline dyes and food ......
JamieDonaldson
...coloring are not lightfast, and I would guess that TransTints would blend well with all the Tightbond glues.
Re: Remember that aniline dyes and food ......
ron bauer
Thanks Jamie, I hadn't considered the issue of permanancy. I still have on my list to call Elmers (Wood Max) and Franklin (Titebond for their thoughts). Ron.
Rob Wallace
Rob Wallace
Perhaps some simple experimentation is in order?
It might be better to think particles rather than liquids.....
Pastels (available at nearly every art supply store) of different kinds are readily crushed into a colored powder which could be easily mixed with wood glues, epoxy, etc. and one would not have to worry about compatible miscibility of the dye chemistry (water, alcohol, or other solvent bases) with the glue, or probably worry very much about interfering with the polymerization and bonding of the glue. The same concerns of light-fastness would apply to pastel powders as they would with liquid-mixed dyes.
Remember that most wood glues are not gap-filling and are designed to polymerize in thin-films between well-fitting, mating surfaces. I don't know how pastel powders mixed in glue will alter the bonding properties of the glue (if any), effect open time, etc., but pastels are cheap enough to give this an empirical test without having to be concerned with theory too much. Crush pastels to a powder, mix with glue, apply glue, and see if it works to change the color enough to satisfy you, while maintaining a bond.
The rocket scientists probably don't have to get involved with this experiment...
Rob
mjonesrdg
Knowing more about your project idea, what you are hoping to achieve would be helpful. Most often, the goal is to hide the glue joint and particulary we don't want black glue lines on white wood. But, not assuming anything, you might wish to feature a color line at a glue joint, or use color to camouflage the glue line as,say, using a red dye with a red wood.
Should you want the color/glue to become a part of the design, perhaps to even appear as a separate lamination between the glued wood pieces, you will need a heavy bodied glue that does not disappear when clamped. An Isophthalic resin or epoxy offers some wide blending possibilities with fillers and pigments. The pigments available will produce a substantial palette of solid (opaque) colors. There are also tinting dyes which will produce a clear, or transparent, color.
Visit Systems Three* or Tap*Plastics (just to name a couple) to see
"Pastel", as an adjective, is defined as a pale color. this may or may not suit your need. Further, a pastel is made up of ground pigments in a wide variety of binders and vehicles. (Chalk, gypsum, oil(s), micropore powders, to name a few. I am thinking that the sheer gross amount of pastel "crayons', needed to color a white glue would have a definite and deleterious effect on the adhesion properties of the glue.
Mike Jones
In Redding, CA
John lucas
Pastels will probably thicken it too much. I use them in epoxy and they work great for that
ron bauer
First of all, Rob, you are spot on about some empirical trials. I was looking for some starting ideas....a little up the learning curve if you will.
Secondly, Mike, I am primarily interested in highly visible albeit thin contrasting colors at the glue line.
Thanks to all who read and commented. I need to go to the lab. Ron.
