Re: Cracks in CA finish
GaryG in MD
I've had this happen on two pens, but I attributed it to stresses from the pressing operation.
On the first one, I had possibly left a little CA on the end of the tube and hence directly where it would be pressed on. So I have started to be very careful to sand the ends flush.
But it happened again. This time, I attributed it to just pressing too hard, trying to get a perfect fit.
Now I'm not so sure.
The two woods I used for the above were maple and amboyna burl. The former is obviously not oily, but I did press against the CA on the ends on that one.
There may be multiple causes for the problem. I doubt Chuck "pressed" on his stopper blank.
I'm also wondering if temperature could be an effect. Perhaps putting the CA on at a cold temperature and then having the piece expand when it gets warm? That might be understandable -- and bad news for CA-finish users. This effect would be worse for larger pieces too. Pens probably would expand a lot less than a bottle stopper.
I really want to learn more about this too. Has anyone else seen this happen? ...GG
