Electronics for a Nichols Lathe
Nick Todd
After not using my Nichols Lathe for an extended period, I plugged it in. I typically use the speed control to operate the lathe. By chance I happen to use the on/off switch the turn the lathe off. The switch failed to turn off the motor. Removed the switch, and the motor ran.
Several Years ago I had a pdf of the manual, but that went with a crash hard drive. I won't be able to get the controller box until this weekend(it's up against a wall.
Are there any ideas?
Re: Electronics for a Nichols Lathe
Josh Bowman
Nick, does the electronics have a name brand, like Teco or Delta?? If so you may can salvage it. The above two run the controls on low voltage and low current. When dust get into them, they fail.
Bill Howatt
I remoted my General's on/off switches and every now and then I have to blow them out to get it to turn on. Looking at my setup, I just can't believe dust could get into the switches but it does.
Bill
Nick Todd
The name started with an "M". I have to move some stuff around to get at the control box. The box has to be opened to see the name. Looking at the wiring at the switch & speed control, I am sure they are low voltage.
