Aspen?? -- Re-post
Dennis in Southern Oregon
A neighbor has a large (16"-18" D) green aspen down. I've never worked with it. Is it trash wood or should I grab some?
Dennis
Aspen?? -- Re-post
Dennis
Re: Aspen?? -- Re-post
Dwight Rutherford
If it's free, I turn.
Saw a demo ( can't remember who ) turned a deep hollow form using Aspen. If I recall it was turned green.
Brad Vietje
Aspen is THE wood for making wooden lampshades -- the most translucent when soaked with a penetrating oil. These are turned end grain, centered on the pith, with about 6" in the center removed.
A 16" log is a little on the small size for these -- 20" - 22" will make a larger shade, and give you more room to work, but you could try one from this tree.
See Peter Bloch's web site for more info and inspirational photos at www.woodshades.com
Safe spinning,
Brad Vietje
Newbury, VT
Randy Gleckler
I think it's great to turn and work with. Carves really easy and works nicely. There's other woods with more character, colors etc, but it's fun to have to work with for new ideas...
Aspen??
Thanks for the help. I will grab a bunch of it. Has anyone tried to make hats with it?
Dennis
Re: Aspen??
Brad Vietje
Hey Dennis,
Great question. I know JoHannes Michelsen usually uses Hard (Sugar) Maple, but has used other species and many burls successfully, too. While the thin lamp shades in Aspen are surprisingly strong, they typically have a thicker area at the top and bottom edge to strengthen them, and they are a fairly strong shape if not flared out at the base. I'm not sure that Aspen would have the strength needed for the brim of a turned hat, but it sure sounds like its worth a try! You could always leave the brim a little thicker to beef it up just a little.
AND, if it's not quite tough enough for you to wear, you could always put a light bulb in it!
Good luck, and please let us know how you make out.
Safe spinning,
Brad Vietje
Newbury, VT
Re: Aspen??
Thanks Brad; maybe I will give it a try with a mini hat before risking the effort to do a full size one. I have had good success with both madrone and sweet gum, but have not tried any other woods.
Dennis
Re: Aspen??
DennisBilevich
I make a lot of vases out of it, and it comes out real nice, if you can rought it out,and and dry, get the bark off ASAP, because the bugs will get to fast, good luck. Let it splalt it is real petty, it's real soft wood so keep your tools sharp.
