Getting a "deep" finish on a bowl is
Rich Pearson in Mill Creek, WA
my latest challenge.
What do you use for that deep lustrous finish?
Multiple coats of spray lacquer.
Re: Getting a "deep" finish on a bowl is
Greg Haugen
Ever since we had Russ Fairfield at our clubs years ago I've never used Lacquer for more than 2-3 coats. He brought examples of his work that were ruined from lacquer. The pieces had air pockets, cracks, and voids under the lacquer from the wood going though moisture changes during seasons and the lacquer not moving with it. Steve Sinner uses a Minwax gloss spar varnish and a quality foam brush. His finishes are lustrous and second to none. The last time I heard, Joe Landon-who makes incredible colored hollow forms, uses multiple coats of gloss wipe on poly. That would be one of the easiest to obtain and apply options.
John lucas
It was just discussed a week or so ago a d I'm typing on my phone which I don't do very well so you may need to do a search to find it. Simply put you sand as fine as that wood needs. The. You apply enough finish to fill on all holes or pores. On woods like walnut this might take a lot or you can fill the pores before you finish. Once you have enough layers on you have to level a d polish the finish. Most of us can't get a high quality finish straight off the gun or brush. By far the quickest ultra gloss finish I've found is Birchwood-Casey's True oil. About 2 or3 coats on Cherry 6 to 10 coats on walnut or mahogony. You have to steel wool between each coat the last layer will be good enough for most people but I still rub it out with automotive polishes.
A simple pretty glossy nice looking finish is to simply sand to at least 1200 grit. Spray a. Oat of semi gloss lacquer and then buff with the Beale buffing system plenty glossy enough for most people but not a glass type finish Very hard to proof read this so hope you can decipher all the errors
John lucas
I've been using lacquer for about 10 years and most furniture is finished with lacquer. Never had a problem. I've read that lacquer is somewhat flexible a d moves with the wood. I know Russ was an expert finisher but his experience with lacquer is obviously different than mine
Thank You!
I will try your suggestions.
I don't know why I never considered a gunstock finish. My 45 year old shotgun's stock is still looking good!
Brad Vietje
Rich,
What do you mean by "deep"?
Looks like most people are assuming you mean glossy and clear -- is that what you had in mind? I think of "deep" a little differently, like the way a great oil finish brings out the color and depth of the wood, but in my mind, glossy is not a requirement. Not incompatible, either, just not a requirement of the way I think of a "deep" finish.
I find that a piece really needs to be perfect in every regard to look good with a very glossy finish... A high-gloss finish will show off any blemish, and sanding mark left behind, any bruised or discolored wood from a trailing bevel heel, etc... Even an extremely subtle change in curvature will stand out as an uneven reflection in a high gloss finish -- think of the tiniest dent in the fender of a new car....
I usually reserve gloss finishes for completely decorative pieces, like ornaments. Anything that gets used or handled will not stay glossy and/or perfect for very long, so I never use a gloss finish for a utilitarian item. These are not established "rules" of design and execution, just my own humble observations. Your experience -- and certainly your opinion may vary -- just my 2 cents for what it's worth.
Safe spinning,
Brad Vietje
Newbury, VT
