I have been turning ornaments. I notice I spend a lot of time shuffling the tools around. I tend to lay them on the ways and then have to move them to move the tailstock. Doesn't seem like much of a problem until you do it over and over all day. What is your solution? Do you have a cart beside the lathe? Tool caddy? I have a tiny shop and don't really want another cart, but it might be worth it.
I have 6 small tools I made or purchased just for ornaments. I have 3 that I use most often for hollowing. 2 were made from Drill rod and the 3rd which is my most used is a custom tool I made using a Hunter #1 cutter. Since they are only about 8" long they don't take up much room and sit on the bed ways between the banjo and tailstock, until I move the tailstock, then they sort of progress further down the ways.
For finials I also have 3 tools I use. One mini roughing gouge bought as a part of a set of cheapies from Harbour Freight, One spindle gouge which is actually a modified Sorby mini roughing gouge ( I ground it into a sort of continental grind) and a 3/8" mini skew ground from a 3/8" spade bit. These are also under 8" in length.
My problem is where to put the 3/8" drill and drill chuck that I use to drill the ornament ball, and the ornament ball thickness measuring tools. The drill isn't too big a problem as I have a tool box with 75 tools to the left of the lathe. It has a large flat surface on top. The biggest problem for me is the thickness measuring tools. No matter where I put them I either knock them off the ways or constantly move them and can't find them. I'm thinking about putting a magnetic platform on the end of my Banjo to lay them in. ONe of those magnetic parts trays you see in automotive catalogs. That way they will be out of the way and the magnet will hold them there.
I o have the same problem and I also lay the tools in the ways where they are handy. Now I have to benches behind and to the right of my lathe. One has a magnetic bar that most of my tools hand on and the bench to the right I drilled 7 holes big enough for my most used tools. It works most of the time.
I have a mobile cart at the tailstock end of my PM3520. It has a tailstock extension of wood that I can slide my tailstock on to and roll it out of the way for hollowing and doing bowls. When I use my tailstock, I have a simple tool shelf that sits on the tailstock extension to lay my tools on that I am currently using. Here is a picture.
My lathe (PM 3520B) sits in the middle of the room, several feet from the nearest wall. So, locating the tools and etc's was a bit of a problem from the outset. What has evolved is a small table and two small shelves at the tailstock end.
This accumulation began with an 18" wooden extension I added to the lathe so I could push the tailstock back out of the way. It's described on my website. I then placed a small free-standing table beside the extension to hold the tools I happen to be using at any given time.
One end of the middle shelf is attached to the end of the extension. The other end is supported by the table. Smaller tools such as detail gouges, a small skew, parting tools, etc. go on this shelf.
The top shelf is attached to the extension and is designed so the tailstock will slide back under it. It holds small items such as calipers, small tools, and so forth.
The whole mess can be removed by loosening one bolt and removing three screws, which I do when I'm taking pics of items on the lathe. In that case, a shop light is mounted above the table and clamped to the extension. I have never removed the extension once I put it in place.
I positioned the headstock end of the lathe near a support post which I boxed in with plywood to form a column. This column now supports electrical outlets and switches, and also holds various small items such as chuck keys, a knockout bar, calipers, live centers, and etc.
My vacuum system sits permanently near the headstock end so I can hook it up quickly. The top of the enclosure serves as a shelf for more small items such as sanding pads and a lot of whatevers.
I put considerable time into building all this stuff, but I have reclaimed that time because, now, most of what I use on a regular basis is within arm's reach. It works for me!
You can see a wider view of the setup on my website, in this article:
There are several good ideas here so maybe mine doesn't fit in. Every year I turn 20-30 wine stoppers and a bunch of ornaments. I was always digging for the right tool so I solved the problem in an easy way. I bought a magnetic shelf from Lowes for 10 bucks, snapped to the tail stock and my tools are always easy to grab. Works for me.
I like the bed extension on the rolling cart -- that solves the problem addressed by the hinged sort of tilt-away extensions very neatly, and provides a moveable cart for accessories, as well.
