Finishing Small Bowl.
Alan Sweet
Alan Sweet
Ok. I am not the world's most experience and in need of some advice.
I am finishing some small bowls on my lathe. I would like to be able to chuck the bowl finish the inside and out. Then turn it over rechuck it and finish the bottom.
It seems that I get chuck marks on previously applied finish and maybe even mar the bowl side. Should I just give up and finish the bottom off the lathe.
This is decorative bowl and I would like the finish the finish to be consistent. Which I doubt will happen if I do part of the finish on the lathe and part off.
I was hoping to use GF WTF.
Re: Finishing Small Bowl.
John Veerkamp
Need more info.
How big is small?
Are you contracting or expanding when re-chucking?
Are you using a jam chuck?
Are you attaching to a finished surface?.
Alan Sweet
Alan Sweet
2-3" in diameter
Tried both ways.
No Not using Jam chuck.
When doing the last part, the rest will always be finished. So yes the chuck is attaching to a finished surface.
Alan Sweet
Alan Sweet
Following John's suggestion of a jam chuck, I cobbled together a jam chuck with rug matting duct taped to the end. This allowed the smaller of the bowls to held by friction while I finished the outside and bottom. Then I just had to tape additional layers on to hold each of the remaining bowls.
But, thanks for the suggestion John.
John Veerkamp
I use cheap vinyl electrical tape instead of duck tape. Doesn't mar the finish and can be stretched for a good snug hold.
Re: Finishing Small Bowl. *LINK*
I hope this link works. I wrote an article a while ago on reverse turning bowls. maybe you can find a method that will work for you. I always turn the bottom seperately from the rest of the bowl so I can turn off any signs of how it was turned (meaning chuck marks most often).
I start my bowls between centers, turn the outside with a tenon on the bottom. Then reverse it, put it in a chuck and turn the inside. Then I reverse it and put the open end over the chuck with a rubber jar lid opener to protect the bowl and drive it. I place the rubber over the chuck and then bring the tailstock up and put it in the hole that it started with. This aligns everything. Then I turn the foot of the bowl all except a tiny tenon where the tailstock was. Carve this off and then sand and finish the bottom.
http://nebula.wsimg.com/7bf500f3fd52b978d800c0fc6f0bf5f5?AccessKeyId=8E1EC0DC707F1FE36FCB&disposition=0
Alan Sweet
Alan Sweet
Thanks to John and John. (They will have to figure out which one I thanked first :) ). Sometime I get the feeling I am back school and everyone else is a grad student.
