Remove Hut Crystal Coat finish
Tim O'Hearn
I would like to remove the finish from a small bowl and apply an oil finish. What should I use to remove the shellac-wax finish. I do not want to remount and turn away till the finish is gone.
Tim O'Hearn
Re: Remove Hut Crystal Coat finish
Dennis in Southern Oregon
The solvent for shellac is alcohol, which should remove the wax also.
Dennis
while this is true...
GaryG in MD
...it would take a LOT of elbow grease, and I don't think you'd ever get the shellac out of the pores. The way an oil finish works is that it soaks into the pores. IMO, these are now permanently blocked in your piece. While you can, indeed, put an oil finish over shellac successfully, I doubt it would have the character of an oil finish over raw wood in terms of how it pops the grain. That character comes from soaking in deeply.
Both shellac and oils yellow a piece. The surface character of both oil finishes and a shellac finish is that they water spot and fingerprint, with or without wax. Both can be buffed to any level of shine that you prefer. FWIW, I believe that wax is overrated, and I have pretty much stopped using it myself, with the occasional exception of Renn. wax.
I'm not sure I see a reason why you would want to make this change, particularly given the above. Others may disagree, but I'd say it's too late to change the basic appearance character of the piece significantly. ...GG
