Making liming wax
Making liming wax
Making liming wax
John lucas
Does anyone know how to make your own liming wax. I would like to make my own colors just never thought about it before. There should be a way
Re: Making liming wax
Bill Turpin in WNC mountains
Recipes on the web suggest a mixture of clear wax mixed with white acrylic paint How about neutral Kiwi shoe polish, warmed in the sun for a couple hours, and white paint. Mix well. Have fun. A cheap experiment
Clint Searl
Clint Searl
Dry pigment mixed into a paste wax. www.sinopia.com
Betty Scarpino
Betty Scarpino
Instead of liming wax, some people have had success just using acrylic paint, probably the thinner variety.
Betty I wondered about that. Thin it a little and maybe add something to make it spread easier.
tomB
The problem with acrylic is that it dries pretty fast. I think if you put it in a solvent (paste wax), it would give you a bit more working time. There are also acrylic products to retard the drying time.
Betty Scarpino
Betty Scarpino
There are two basic types of of acrylic paint, one is thicker (soft paste), the other thinner (sort of the consistency of cream). I've tried both and the thinner works better, but both types do dry fairly fast, which means there could be a problem if not applied and removed properly. So, experiment, but try the thinner consistency.
I've also used metalic-gold paint as a liming-wax sort-of application. That turned out really nice. Did it on small items, though.
The key to success with any of the liming wax-type embellishments is to make sure there is a thick enough barrier of whatever clear finish you are appling the wax/acrylic/paint over. You want enough clear finish to create a barrier, but not so much finish that it fills up the wood pores.
Betty I've used Rub-n-buff which comes in gold, copper and silver and it works well but can be a little hard to remove sometimes if you don't work quickly. I have some modeling paste and now some Moulding paste from Golden and I'm going to try those. They are thicker than the Rub-n-buff and take color well. The Rub-n-buff is almost too thin in that it gets into the extremely tiny pores pores in the wood. Could be I haven't applied enough finish to the wood first. I'll let everyone know how the two pastes work. they are acrylic and should clean up fairly easy but they do tend to dry fairly fast in thin layers ( not fast enough when used as cupcake icing but I'm working on that). This means I may have to work on smaller sections at a time, rub on wipe off, then move to another area.
Betty Scarpino
Betty Scarpino
Even with liming wax, I need to use 0000 steel wool, but liming wax always comes off. Indeed, not quite as true for acrylic.
If you end up getting a drip of finish that completely closes a small area of pores here's a hint: Take a fine needle and prick open the pores so the liming wax can be spread into the openings.
Jesper, Denmark
Re: Maybe I'm missing something....
Jesper, Denmark
But, could you not just add some TiO2 white Pigment to regular wax? Or to shellac or any other favorite finish?
you can probably add it to wax although I'm trying to get away from just plain white. You need to be able to remove the liming wax from the flat surfaces and leave it in the grain. That's why it would be hard to use shellac or other finishes.
Is real liming wax really a wax, and .......
JamieDonaldson
...wouldn't a wax interfere with an overcoat of most finishes? The liming "wax" I have infrequently used appeared to be more of an acrylic pigment/thin paint paste, and most is wiped off anyway. :\
Betty Scarpino
Re: Is real liming wax really a wax, and .......
Betty Scarpino
Jamie, I'm not sure I understand your question. Are you saying that if you wanted to apply more finish after the liming wax is applied, then wouldn't the wax then interfer with that final coat? Probably so. But I don't apply any more finish after applying and wiping off the liming wax. If you wanted to apply more finish, that application over liming wax would most likely be a problem.
My liming wax technique: Use ring-porous woods, ash works the best. Sand the wood to at least 220, getting all the scratch marks out (scratch marks fill with liming wax ...). Saturate the wood with dye. Let dry. Spray with Deft semigloss. Three coats are usually sufficient. Very lightly 0000 steel wool the surface. Apply liming wax, wiping it into the pores. Wipe off excess with paper towel. Then use 0000 steel wool to remove the residue of wax, which should come off easily.
Just a note: A liming wax finish can be beautiful, but it is a bit of a challenge to repair if the wood gets scratched, but it can be done. I don't recommend a liming wax finish for utilitarian objects.
I have applied a final coat of....
JamieDonaldson
...spray lacquer over liming wax, to seal the wax, and several times it worked but other times resulted in orange peel or fish eyes. Wiping finishes also eliminated much of the liming wax effect, so I've wondered about how to best resolve this dilemma.
Betty Scarpino
Re: I have applied a final coat of....
Betty Scarpino
I think if you waited long enough and made sure the liming wax was thoroughly removed from the wood's surface, the spray lacquer should work fine.
Peter Hyde
I made a solid ash counter top for my bathroom vanity. Sprayed on 2 coats of black nitro cellulose lacquer. Allowed it to dry 10 days and then 0000 wire wool and vacuum dusted. Used Liberon liming wax and followed the instructions but no matter how hard I tried I couldn't get back to black using a clear wax to remove excess liming wax. So I used pure turpentine to take off the white haze. Used sparingly on a soft cloth and a lot of elbow grease allowed me to get just the right amount of liming and a nice black background. Left it for 10 days and then 2 coats of lacquer for a topcoat. Installed it when dry and after 1 week it became very obvious that the lacquer was lifting from the finish. So back to the shop and stripped and then went through the whole process again but this time used Danish oil to take off the white haze. Left for 10 days and then oiled it. Left for another 10 days and applied the lacquer finish coats. 5 years in heavy use and still OK
Mike Stafford
Mike Stafford
Ed Moore taught me this method of using liming wax. First finely sand the piece to which the liming wax is to be applied. Apply your dye if you are going to use any. Remove any raised grain and excess dye making sure the color is uniform. Then dust and apply a light coat of spray lacquer. Remove any raised grain and then apply the liming wax. This allows the wax to go into the deeper pores, cracks and crevices but not into the "field" of the wood. Wipe off the excess liming wax going first against the grain to force more wax into the pores and crevices. Then wipe with the grain to remove any excess. Allow the liming wax to cure. Ed was of the notion that it was a pigment that needed to dry and if you have noticed how crusty the paper towels used for wiping become after a few hours I think he was right. Finally top coat with a good paste wax and buff. This method gives a nice finish in my opinion.
