I am making some Ornaments. I was thinking it might sell well if I had some with red stain on otherwise white wood. Or maybe green? What does one use for a hint of red or whatever? The other question would be is this a good idea?
Is it a good idea? That's for you to decide. You can use just about anything to add color. Acrylic paint, dye, milk paint, ink. you get the idea. If you use anything water based, it will raise the grain and make finishing that more of a job.
Water based dyes penetrate the wood so they don't hide the figure and character in wood. When I use water based dyes, I sand well to 400 and then wet the wood pretty thoroughly with a sponge or rag. After drying I lightly sand again with 400. After drying I apply the water based dye. The sanding schedule usually eliminates grain raising from the dye, although I will run my hand over the wood after the dye dries.
I have never tried to thin it. I am usually looking for either some small detail lines or to cover one of the elements on the ornament with a nice bright color. Now when I am coloring something, it is usually a pretty dull, no figure, cheap kind of wood. If I have great wood, the ornaments are always all natural.
Gary Sanders does some great stained ornaments, I would suggest you look at his work, I think it is closer to what you are looking for in terms of seeing the wood grain under the color. I think he as done some teaching down at John C. Campbell. I really like his work.
Barry, I use stains often with ornaments and for red I like the Varathane Cabernet color. The little sample packets are often all you need for a project. I've used cabernet with dark woods like walnut to add a warm tint and with lighter woods to get more of a red color. I reuse my paper latte cups and invert them to mix stains and finishes in the recessed bottom of the cup, then apply it with small artist's brushes. Most ornaments are tough enough to be polished by buffing to give a nice shiny finish.
Purpleheart has a great grain and will accept a cabernet stain, giving a nice deep red that is the color of the darkest red on a red delicious apple. Ornaments may be made of layers/laminations of wood and by using a wire to burn a small groove, the band is defined and easy to color with some stain/glaze and the inexpensive artist's brushes. Wood burning and other methods to texture a band or two can add to the color and further add interest to your ornament.
