Veritas - Innovation in Tools
Repairing chuck key Question
I have one of the Nova chucks that uses the Tee handled chuck key that has the swivel head with the gear teeth. The earlier version before they went with the Allen keys. The handle is pulling out of the head. There appears to be an internal split ring that holds it together and that is about half out. I tapped it back in with a punch (OK, I used a cheap screwdriver) and that worked briefly but not really.
Has anyone taken one apart and put it back together? Any advice? From a previous post about someone losing theirs, I gather they are hard to replace.
Re: Repairing chuck key Question
Don Evans
I went through that problem several years ago. Unfortunately they didn't make that ring out of spring steel. Once it comes out, it will continue to do so with just the slightest movement of the handle. Back then, Teknatool sent me another key so I took the handle out of the old one and filled it with JB Weld and a 1/4" snap drive that I cut off one that had a magnet in the end. Since I use it in a dedicated drill driver to turn the jaws when I have to move them from one extreme to the other in open to close or vice versa.
If they had not replaced it I would have looked for a snap "c" ring to fit it, might have to do a little grinding on it with dremel and stone to make it fit. Might even have to put more than one in it.
Don
Thanks for the reply,
I was beginning to think I had stumped the collective wisdom of Wood Central.
I am surprised that is not a snap ring.
I had another key so I have been using that, but it occurred to me I need to repair this one because if the other one blows up, my chucks are dead.
Wonder if the chucks can be converted to the Allen key system?
And if I can't figure out a more graceful repair, wonder if I can JB Weld the handle into the head? Or have it welded?
Re: Thanks for the reply,
Don Evans
I'd have to see it to make this statement more clearly BUT not that I have given it some more thought I don't see reason for not JB Welding just the old ring back in place. You would need to be careful to not get the epoxy on the pin that goes through the handle though. If it gets glued you will lose the benefit of the handles ability to move back and forth.
Take a look and see if you think you can do the gluing and keep the area clean of glue where the cross pen touches the ring.
Use the slow setting JB Weld just along the top of the ring but make sure to bend the ring so it fits the groove, also open it little so it will be best tight fit you can get then spread the glue on the top of the ring and up the side of the thing to give the glue more contact area.
Let it cure for several days before moving it.
Be sure to let us know how it works out or if you come up with a better way.
Too be clear, when I say "ring" in this message I am referring to the original ring NOT a new snap "C" ring.
Don
