Starting to move big stuff into my new shop. My mini-lathe will be positioned on a bench parallel to a wall. I'm not sure how to position my big lathe, though. Do I use up wall space or floor space? (Jet 1442)
Do you have your big lathe parallel to the wall, perpendicular to a wall or angled out? Why?
My PM 3520 is parallel to and out from a wall about 20". This allows for a shelf at arms reach over the lathe bed (chucks, drives, calipers, tape measure etc.) and the dust sucker mounted below and along the same wall. All electrical convenience outlets spaced along the wall for lights, drill motors, sharpening station etc.. there is room to get between the wall and the lathe, but I seldom need to go over there.
I do a lot of hollowing of fairly large pieces so I stand at the end of the bed frequently. For that reason I have mine positioned in a fairly open area. I need at least 6 feet or more at the tail stock end and a couple of feet to each side of the lathe bed.
I to have mine positioned similar to the other two posts. Only thing I did just a bit different is I kicked the back end of the lathe out about 6 inches more than the front of the lathe. It helps me to get back there to scoop up chips.
Joe, I have mine (PM3520) positioned perpendicular to the wall, making it easier to get to the "wrong" side of the lathe for doing peculiar cuts, hollowing, etc., and making it easier to hollow from the end. I also use hollowing jigs that are positioned at the end of the lathe.
Joe, I have my big lathe perpendicular to the end wall of my shop and parallel to the side wall. I have it positioned so that my back is to the side wall. I have my tool rack on the side wall so that it is easy to turn and grab a tool or replace a tool.
I used to have it parallel to the wall. When I got my oneway, a friend warned me that if it is parallel and the tools are in a cabinet on the wall, it only takes one time reaching over the lathe while running to create a disaster. I prefer it perpendicular now, for safety, access and cleaning.
The lathe used to face the other way - looking at the wall. I turned it around to do a demo for some friends this spring, and now I like it much better this way. The curtain keeps that major debris away from the rest of the shop. The distance between the lathe and the wall is around five feet - close enough to encourage you to put tools back directly, and with enough space to move. I can also see through the curtain, so it feels better than always having your back to everything.
The grinder, abrasives and auxiliary supplies are close at hand. Sweeping around the lathe is easy, and the dustcollector can easily be moved into place for sanding.
I built an enclosed room for my Robust. Shop is a 24 by 36 pole barn, and insulated. The lathe sits in an 8 by 12 room, in a corner. One reason to have the sliding headstock. It is parallel to the wall, with just enough room to swing the tailstock away. Tool racks and grinder are behind me as I turn.
We don't usually need to walk around the headstock but we need access to the tailstock end and BOTH sides. I suggest an angle to the wall with the headstock far enough away to get the knockout bar in. The 1)tool rack, 2) grinder, 3) workbench should be within arms length. I use a triangle set up. Like in Jespers photos he has access but has to walk away from the lathe to use the counter top for gluing, faceplate screws and just set stuff down while in use like sanding disks and drill etc. If I were Jesper I would tilt the lathe so the bench workspace were behind me for easy use.
I did not mention that I think your shop size has a lot to do with how you position the lathe. My shop is 10' wide and 30' long (3rd car garage). If I ran my lathe perpendicular to the 30' wall I would be constantly working around it. So I positioned it where I had the most access to tools and benches and yet still have a dust collector and access for cleaning on the back side.
If my shop was larger I would position the lathe near the overhead garage door so I could open it and clean with ease or better yet have a setup like Glenn Lucas uses. The short of it is place it where it makes sense for flow in your shop and shop size. Then you will probably tweak it here and there until it is perfect for how you work.
Mine is set up angled as Lyle suggests. This allows me easy access to turn from the end or get on the other side. I have some small items within easy reach on the wall to my left. I would not want to be tempted to reach across the lathe to grab a tool off the wall. The wet stuff has further to go before it hits the wall and streaks it up. I have recently added a shower curtain behind the lathe to keep the wet crud from landing on my BS.
I will be moving shop in a few months. The exact layout has not been determined (sharing the space with others) but my long bed Stubby will either be perpendicular to the main wall or angled with the headstock towards a corner. I visited Mark Salisbury's shop. He has the same lathe set up on the angle and it feels so comfortable and natural.
It's not too obvious from the pics, but there is a red door between the bandsaw and the curtain - access to a storeroom. So there needs to be a walk space in front of the curtain. Also, the bench top is infeed to the chopsaw, so cannot be moved.
Due to space constraints, I have my lathes positioned parallel to the adjacent wall, but if I had the real estate and a chance to "do over", I would have the lathes angled at about 30 degrees from the adjacent wall to have better access to the tailstock end for hollowing and ease of clean-up. Conversely, having a wall close by (within one's reach envelope) is very handy given the increased opportunities for efficient storage of tools and turning supplies.
One of the considerations with a lathe positioned parallel and close to a wall is the possibility of having items launched from the lathe hit the wall and bounce back at the operator. While not a major consideration, there have been reports that this has happened; with an angled or perpendicular lathe this possibility is greatly reduced. The same workstation design principles should apply whether the lathe is parallel or angled to an adjacent wall. Some a;so put the lathe in a central or "island" position, for total access, but for many this is impractical.
The document at the following links may give you some additional things to think about when setting-up your lathe:
Having the lathe parallel to the wall is OK as long as it is pulled away from the wall. You need about two feet from the centerline to the wall. If the lathe is next to the wall it limits your turning capabilities. You can not even use a bowl gouge correctly with a bevel supported cut at the rim. The handle is often perpendicular to the bed sticking out behind the lathe. This could affect both your access and creativity and safe use of tools.
