I actually counted 80 beads per ring
Steven Antonucci
steven antonucci
but yes, exactly like that!
I think if you have much larger beads with larger holes in the middle, they can be butted against each other pretty hard. However, these beads are 11/0 and the hole is roughly 1/3 the diameter of the bead. In general, I can only pass 4 threads through the bead. Since the thread and the bead are on the same scale, it matters.
If the thread was up against a 2" segment, I bet it wouldn't matter at all?
Good... ahem, thread ;)
S
