I want to turn a bottle stopper for my fly fishing friend. I plan to turn a recess in the top and encapsulate a fly in the recess. My question's are "what to use for encapsulating the fly" and after using it, "what finishing steps will be required". I was thinking about clear epoxy but have not had time to experiment.
It's hard to find really clear epoxy. Casting resin is a better choice but is expensive. You can buy it at Micheals and Hobby Lobby. I use Cast-n-craft. You turn it just like wood but you have to sand to a very high grit and then polish it to make it really clear.
Another product that will work is System 3 Mirror Coat. You can get it from Woodcraft. It's not cheap either but is an epoxy so you can use it for other things later. You'll have to sand and polish it also.
Another problem is suspending the fly but you can probably put a wire under it that won't be seen. You will also have to seal the wood before pouring the epoxy or resin into the hole. If you don't it can soak into the wood
I have worked with flies quite a bit. I use "Pour-On" resin (from Michaels) to suspend them. First, I dip the fly in the resin and swish it around to try and get any air bubbles out, then place it on a plastic cutting sheet, place another cutting sheet on top and weight down. Leave overnight for the resin to set, and you will end up with a resin disc with the two dimensional fly imbedded. Trim the disc to size and place in the recess that has been prepared and sealed in the bottle stopper. Fill the recess with "Pour-On" and let it set overnight. The resulting surface will be as smooth as glass. If necessary to cut, sand, or shape, it can be recoated with "Pour-On" to restore the gloss, or sanded to a very fine grit and coated with other finish. I would suggest coating the whole bottle stoper with "Pour-On" after finish sanding for an awesome glossy finish.
I recently used the suggested clear polyester casting resin when embedding "special" items in a turned gift. Three notes: (1) don't forget to buy the catalyst (sold separately for like $7); (2) curing time was much slower than expected, in fact it was so slow--i used a garage sale toaster oven to harden the blanks; and (3) the hardened material is very chippy when turning--a super sharp edge or carbide cutter worked best for me. Good luck!
To Vince's suggestions for turning, allow me to add one: measure very carefully so you know exactly how much material you can remove before exposing the embedded fly. Once you start turning, the material will become opaque. You will not be able to see the fly and will not be able to see if you're turning too deep until it's too late.
