ADVERTISE HERE - FREE TRIAL
creative uses for shavings
Darrin Hill
I have a path from my house to my shop.. and the path is made of circle slabs of concrete from lowes.., grass grows between them...
over the past few years, the slabs have sunk into the earth and started to disappear... i was wondering if it would be ok to pull up the slabs and put a really thick 6 inch or so mound of shavings all the length of the path and put the slabs back on top... or should i stick to gravel or rock base...
but i also use it as mulch around flowerbeds, etc.., was wondering if anyone has other creative uses for shavings...
Re: creative uses for shavings
Jorge
I use some to start the wood burning stove, but for the main of the bulk I start compost piles and eventually those compost piles get spread in the garden and field.
Mike Stafford
Mike Stafford
John C. Campbell Folk School has miles of paths throughout the school which are several inches deep in wood shavings. Of course with a turning class every week with 8-10 students it is amazing how many chips and shavings are produced. The shavings continually decay but do a great job of preventing erosion and weed growth.
Like Jorge I compost all my wood chips using 3 compost bins so that the chips decompose over the course of 3 years before they end up in the garden. I turn small stuff most of the time but even so I make a surprisingly large amount of chips. When visitors to my shop see the pile of shavings I tell them I eat them which is true but in a different form.
Dale Miner
It would be best to put gravel under the circle stones. Wood shavings would decompose in short order and the stones would settle back to nearly the same elevation. Mulching the path around the stones sounds like a good use.
I put my shavings and sawdust along the fence that borders a wooded area. It helps keep the honeysuckle at bay under the overhanging tree branches where it is difficult to mow.
Dale Bonertz
I take them to a chicken farmer who uses them as bedding for the chickens.
John Veerkamp
Mesquite, Cherry and other fruit woods are used for smoking in the grill. All others are used as multch , soil conditioner and weed barrier.
Don Orr
I give my clean domestic hardwood shavings to some pottery friends that do Raku firing. Other stuff goes in a yard debris pile down behind the pond to decay.
Hal Taylor
Although only a small bit of my shavings are used, my daughter uses them for bedding, etc. for their guinea pigs. They seem to really enjoy them.
Dick Hines
Dick Hines
I have a friend that has chickens. When I get 8-10 bags I call him and HE comes and gets them. No fuss, no muss.
Harry Robinette
Harry Robinette
It does work good for mulch but don't put it up near your house. The rain will bounce off the chip's and put a stain on your siding that's really hard to get off aluminum and WONT come off vinyl.
Emmett Manley, Lakeland, TN
I do some gardening under black plastic, a process which keeps the moisture in and the weeds out. Also, black plastic really speeds plant growing in the early Spring.
However, when summer arrives in Tennessee the black plastic would become so hot as to burn whatever I was growing except for the fact that I cover the plastic with wood shavings. The shavings keep the sun off the black plastic and retain moisture from rainfall. Also, the shavings do not blow off the plastic as happened when I tried to use newspapers.
At the end of the growing season, I just dump the now rotted shavings into the garden as mulch for the following year. Rotting wood burns up the nitrogen so I add some granular fertilizer to the shavings.
spalting?
Darrin Hill
so how about a big pile of shavings beside the shop for a spalting garden?
Jeff Smith
Most of my shavings get composted or, if there's a lot, I take them to the county composters - they love clean shavings and take them for free, but some wind up in the dogs turn out area - its about 15 x 20 feet and they seem to like the idea. I try to refresh a new layer about every two weeks. Makes cleanup easy, too, and the 'land mines' are easy to identify.
Brad Vietje
Heat Your House or Shop With 'em!
Brad Vietje
and not by burning them, but composting them... No Kidding. If you have a LOT of shavings, you can build a "Mound du Pain", or Pain Mound, and use it to heat your house, make hot water, and even make natural gas for cooking -- all from composting wood chips.
Details found here: http://www.compostpower.org/
I am absolutely not kidding. Anyone who is a production turner or cranks out a of shavings or sawdust has piles of gold on their hands. A turning school like J.C. Campbell could heat or a large volume of water for showers, etc with such a system. Really -- no BS and no gimmick at all.
I live in a straw bale house in Northern Vermont where we have roughly 8,000 heating degree days, and we've looked quite seriously into getting our heat and hot water from a Pain Mound. There's no requirement for any sort of alternative construction like we have, but we can get through a winter in comfort with only 2 cords of firewood (our only heat source), so our house is very well insulated, and thus a good candidate for space heating via composting wood chips. Even if you live in a tent with no insulation, you might be able to save 300 gallons of oil or 400 gallons of propane or natural gas by heating water with a waste product -- and generating a cash crop of compost at the same time.
I want to do this, but my wife is not so keen on it.... so you know how that goes.
Safe spinning,
Brad Vietje
Newbury, VT
