cherry faceted box
cherry faceted box
cherry faceted box
I've wanted to do this for a long time. Make a box and then sand facets into it. Dummy me picked cherry which of course burns too easily so I had to use a courser abrasive than I wanted and man did I have to touch it lightly. Got it all finished and then realized it was very hard to properly align the lid. Solved that problem by texturing one facet with my Dremel engraver You can see it if you look close. It's far more subtle when you hold it in your hand. it's about 4 1/2" tall.
Re: cherry faceted box
Bob Edwards
But can you replicate the outside on the inside?
Just thinking of skills not learned.
Seriously, Nice box!!
cool idea, John
GaryG in MD
I like it.
And the "surprise" inside of the lid is very nice too. ...GG
Steven Antonucci
like it.
Steven Antonucci
Surprise inside too.
S
Cyril Griesbach
Quite impressive, John. I like everything about it.
Sweet!
Hal Taylor
Neat box John. Good idea. Now do one with threads.
Another faceted box
I ground the facets on my drum sander this time. I think I like that better than the flat disc. The flat disc works fine on the curved lid but was difficult on the larger flat areas. A 2 1/2" drum worked well for getting into the flat areas and still left a facet that looks about the same.
I took my propane torch and burned it slightly. Then I reduced the flame on the torch and burned one facet to make it easier to find the proper lid alignment.
Re: Another faceted box
Lan Brady
The added buring techniques- Homerun!!!!!
George Taylor
What about color
George Taylor
I suppose you could also color the piece (milk paint or even dye) and then sand away the facets. I see another video in your future (hopefully).
Greta job John
Randy Gleckler
Really like that, it set's everything off. Nice work John.
Re: What about color
George I'm actually painting a stool right now with Milk Paint but all these boxes have been out of cherry and I hate to paint it. When I make one out of plain wood I might. However then it just looks like ceramics or glass so I may or may not do it.
David Walser
John - I thought that the idea was to paint the box and then sand the facets. This would leave just a trace of the paint framing each facet. The effect would be similar to what you achieved with the torch, but leave a painted frame around each facet rather than the charged frame left by the torch. This approach would not cover up the beauty of your cherry.
Of course, the technique might require more care in sanding the facets. I'm not sure how it would look if the thickness of the frame was inconsistent from one facet to the next. Variation might enhance or detract from the effect. The paint might also gum up your sand paper. Still, I think it would be doable and worth the time to experiment. (Notice how free I am in spending your time?)
I might have misunderstood the original suggestion. If so, I apologize.
Sergio
Congratulation for a super idea and results!
Here's some color
Carved this using the oscillating spindle sander and then used an Ink Brayer and red ink to roll onto the high points. I may have used too much pressure because it rolled into some of the dips.
George Taylor
That was what I was suggesting ...
George Taylor
... that could open a world of possibilities.
Very good
Ralph Watts
John,
Great job! I really like these guys.
Best regards, Ralph
