What do you do when you aren't good enough?
Steven Antonucci
steven antonucci
Woke up Sunday AM with a very clear idea and a goal in my head. I had a project to "get out" and it involved turning and another skill. The turning part went as expected, and the other part didn't seem like it would be that difficult.
Shame on me for thinking that.
Turns out that this other skill, which is very simple in appearance, is very difficult to do. As with anything, I found some videos on YouTube, and said..."Oh, I can do that". While I have done this type of work in the past, I've never attempted to combine it with woodturning. There are aspects of the skill that I can do, but other parts that I need a lot of work to be able to finish this project.
What do you do with a new idea when it is more than your current skill? Can you wait it out until you are "good enough?"
Steve
Re: What do you do when you aren't good enough?
John Veerkamp
waiting doesn't cut it for me. Jump in and at least start prorotyping. Good enough comes with technique familiarization and practice. One of projects are more problematic however. How much time and effort does one invest for a one time thing?
Alan Zenreich
Alan Zenreich
I simply let Lauren handle those things...
John lucas
If you want it bad enough you dig in and practice until you learn it Sometimes you just have to wait because life gets in the way or to many other projects jump to the head of the line. Most of the time if you want a project bad enough you'll figure out how to do it. I have several things from the past that I built and I look at them today and don't know how I had the skill to build it. There is one i built that I've kept. I'm going to rebuild it because I know my skills are better today a d can improve it
Steven Antonucci
send her over...
Steven Antonucci
If she knows how to peyote stitch.
Lyle Jamieson
Re: send her over...
Lyle Jamieson
My wife Dori is a beading artist and uses the peyote stitch all the time. It does not appear to be difficult but it is difficult to learn from written instructions and observation. Find someone to help you get started, that has the skill, and it will come quickly for you. It takes significant planning to lay out the patterns but has cool applications. She has used some of my turning as a palate to bead on. So it is do-able. Yes, even when you know how to do the stitch it takes some extra skills to translate it to a rounded surface.
Steven Antonucci
Exactly my issue, Lyle
steven antonucci
I agree that it is not very difficult to do, but becomes a very different thing translating into round surfaces. Add to the face that the round surface needs to be calculated into a pattern working a 11/0 scale... and you'll understand my frustration.
Add to the whole mess that I ran out of beading thread this weekend...
Steve
dick gerard
peyoye stitch!?! I never stitch my peyote. I just eat it or brew it into a tea. Who knew you could sew peyote?
clay foster
Collaborate with someone who has the skills.
robo hippy
Sew, what exactly is a peyote stitch? I learned hand sewing through an Indian Lore class at the local Y when I was a kid. It includes leather and bead work. That translated into making footbags (aka Hacky Sacks) for years. Patience, good light and glasses, plus a 'feel' for thread tension to keep things from puckering when you don't want them to. The 'feel' part is very important, just like in turning.
robo hippy
Steven Antonucci
I am a C- stitcher
steven antonucci
It's a number of problems. First, I know that I am the wrong personality type to try to draw a pattern. Even if I found a pattern, I don't know that I could follow it... I am not that structured. (It's probably a bad match for me to be interested in anyway!)
I am familiar with the mechanics of peyote, and I can make the tube, but as I found out this weekend, patterns get wonky pretty quickly when your beads are different sizes and your stitches are even more varied. My wife is a cross stitcher, and if I was smarter, I would follow Clay's advice and just dump it on her... but I am pretty darn pig-headed, and I (for some reason?) think I want to be good at this (I am not sure why...?)
I also thought I might want to look at Mokume Gane in polymer clay as an alternative... and I may just look at that as plan B. I know that I don't know what I don't know about polymer clay...
S
Steven Antonucci
The offending item...
steven antonucci
Sort of "two spools" on top of each other... had intended on peyote stitching the "threads" on...probably still will, unless the polymer clay idea gets legs... yeah, I know it's kind of a waste of some curly figure, but what can you do?
S
Alan Zenreich
Alan Zenreich
I mentioned "peyote" stitch to Lauren and she quickly said "I hate that stuff".
She then qualified her comment (making it less harsh, and giving respect to those who do it) by saying that it was not something in which she wanted to invest her time.
Then again, she's been 'tatting', and that took a long time to develop the muscle memory to be even a little productive.
Steven Antonucci
I was joking
steven antonucci
I wouldn't stick someone else with my problem. 20 minutes of turning for 3 days of stitching... at least... she'd never talk to either one of us again!
S
Re: The offending item...
Steve I've only messed with polymer clay a little. didn't like it. Hard to mix up to the desired consitency I though. Maybe I was doing something wrong. The other 2 factors that may not make it desirable. it's fairly fragile. Tried using it for my cupcake icing and it was far to fragile. You could break off a piece by just barely touching it. The other factor is wood movement. I didn't run any tests on Polymer clay to see if it moves or not. I doubt it. Your box is pretty small and won't have much movement but still I would worry about it. Go with the beads.
Lyle Jamieson
Re: Exactly my issue, Lyle
Lyle Jamieson
I hear you...it takes a ton of patience to figure it out. It is certainly not my thing.
Lyle Jamieson
Lyle Jamieson
Don't know if your question was serious or satire. But some might not know that it is taking one glass bead at a time and stitching them together in a brick pattern. Add the color options and it will look like a loomed piece. There is no backing and the pattern of the color will be the same on the front and back with no visible threads showing. Each bead has to have the thread go through the hole multiple times. Yes, a good comparison on skill and patience would be tatting...which my wife also does. The form you have, Steve, would be relatively easy, think about doing a sphere...not on my bucket list.
Steven Antonucci
The form was "the easiest" I could think of...
steven antonucci
I have other ideas... If I cannot master a tube, I am never going to move up...
S
Peyote Sticth - How To
charlie belden
First, get yourself some peyote.
Take the peyote.
Wait about an hour
- it'll come to you
or
- you'll find something entirely different and equally interesting to try.
DAMHIKT
Randy Gleckler
I have a whole shelf full of things I'm waiting for me to get good enough, or come up with a better idea for. It's not like I'm running out of ideas so I figure they can sit on the shelf until my skills grow, or ideas come back to it. So far it's worked well for me, Some successes, some failures, all gain me knowledge.
