Question on Bangles or bracelets
Anyone know the approximate size of the hole through a bangle or bracelet?
I am thinking of doing a craft show and though they might be a good addition. Anyone sell any? How much? and what sells?
Re: Question on Bangles or bracelets
Steve Kniffen
I've made a lot of these for family members. The size depends on the size of the hand. I make them 2.25, 2.5, and 2.75 inside diameter and that seems to cover everyone. I can't make them fast enough to sell any, they keep getting "appropriated" by the women in my family.
We have a guy in the club that makes them...
steven antonucci
Essentially, he laminates his own plywood from various hardwoods and exotics, and makes them segments. He'll make them in bunches, and I think he's getting $30-50 each at the gallery.
They are extremely well finished, as they are worn on the skin. He used to be a finisher for Tiffany's, and worked on the NBA trophy and such.
Steve
John Veerkamp
It is amazing how much a 1/8" in diameter makes in the fit of a bracelet. I've made dozens, My wife wants 2 3/8 not 2 1/2. Few women need bigger than 2 5/8. The determining factor seems to be how much the person can scruntch up their hand.
Emmett Manley, Lakeland, TN
I have made a lot of bangles and 65 mm is my standard diameter although I have custom made them 53 to 73 mm. The determining factor is the lady's knuckle diameter -- you want the bangle to barely slide over her knuckles so the bangle will not fall off.
I label the inside diameter of each bangle, along with the name of the wood used. I have a set of simple wooden rings of different diameters I use to determine the size a lady requires.
I make bangles by using a small diameter screw chuck or a glue block -- that way, the bangle is cut from the blank by coming in from one side only. This method is quick, provides a smooth inner surface, and leaves you with a perfect blank to make a napkin ring, which is, after all, just a small diameter bangle.
Alan Sweet
I make bangles . Normally, the sizes run 7, 7.5, 8, 8.5 and 9. Those number correspond to the number of inches in circumference a bangle needs to be to fit over your hand. The size of the wrist is important, but the important size is the necessary circumference to fit over the hand.
My wife wears a size 8 and 90% of what I have sold is size 8. These are 2.5" in I.D. diameter. The O.D. will vary depending on the style you make.
