Re: Woodburner Feedback
Don Evans
The important thing with these is to learn what the wattage rating is on the unit. You need at least 100 watts to have a good all around unit. It will get plenty hot with larger tips and can be turned down for smaller tips. This ability also gives you good shading ability for light and dark to the point of making charcoal if you want.
Last I checked, few years back the Burnmaster had a claimed 130 watts.
Don't be fooled by the 2 plug in ports for pens, what they never seem to tell you is you have a switch that switches back and forth between the two plugs so you can only heat one pen at the time. It does add a bit of convenience but that is all.
I have had a Detail Master for many years, the Sabre which is 100 watts but I don't care for their pen handles so I made my own. I also converted it to a 2 port myself for about $15.00.
I also purchased a ball pen from Razor and like it.
When the Detail stops working I plan to get a BurnMaster also. You can get cables and adapters to make any unit work with any pen.
Don
