THE WOODRAT IS BACK!
Woodturning Finish
Woodturning Finish
Alan Sweet
Woodturning Finish
Alan Sweet
I normally don't like High Gloss Finishes. I will be needing to complete something with a High Gloss Finish and was wondering about the Behlen WTF. I would use GF WTF (and probably will) but has anyone compared the two?
Re: Woodturning Finish
Philip Duffy
Alan, I prefer Waterlox for the finish you are describing. An alternative is the new General Finishes Woodturners Finish which is water based and gets a nice shine and it is hard, really hard when dry. Phil
Any gloss finish will give you a high gloss if you build enough coats and then finish the finish. by finish the finish what I mean is leveling the surface to get rid of any streaks lines or bumps and then polishing it with finer and finer grits or polishes.
Typically oil finishes don't build as fast and take many more coats. What type of wood it is, whether you fill the grain and how fine you sand all affect how many coats it takes. It also depends on whether your talking about a glass like surface or just a glossy that doesn't look like you have much finish on it surface.
The fastest build and easiest that I have found is Birchwood-Casey True oil. About 8 to 10 coats steel wooled between each coat will fill in Walnut which has some pretty good sized pores. It does impart a pretty good amber so it looks great on darker woods, not as good on maple if you like the light color.
Spray on lacquer is good but of course you need a place to spray. That's what's on most furniture which should give you an idea of how it looks.
Wipe on finishes like Minwax Poly and Waterlox take more coats but do leave a nice natural looking gloss. If you want the glass like gloss you still need to build more coats and finish the finish if you want a truely superior gloss finish.
Most gloss finishes that go on quick tend to look like a layer of plastic so I stay away from those.
steve worcester
If you put this into two categories, applied on the lathe or by hand (maybe a sub-cat) and sprayed (then sub categorize that as can vs gun) , you can better determine your needs. But I will only talk about solvent based, not water based (I know water is a solvent, but not in this context)
Gun sprayed will be quicker and less coats that anything applied by hand or can. There are a lot of great easy spray products and you don't necessarily need fancy equipment. You can use some Hood Finishes Magna-Shield and get terrific results.
But with spray finishes there is a bit of a steeper learning curve than with hand applied.
With cans, you have to learn to work with thinner coats and usually more orange peel. Not really a problem, but does require more prep work before polish. Orange peel would need to be sanded down to a flat surface before that stage.
When you get good with a gun, or uber-good actually, you can go right off the gun with no polishing. That means no sanding or buffing scratches to deal with. That assumes you have a product that drys fast enough for your environment you don't get dust in the finish (or bugs! Darn bugs!)
The other option is to befriend someone who shoots automotive finishes and pay them (or trade wood turnings) to shoot if for you. That is the best way to do it. The automotive clear coats will give you a clearer, higher solid, glossier finish than I think you can achieve with typical wood lacquers. I know, there will be people who disagree, but this is my opinion after shooting all of the product above in my own environment.
Dick Hnes
I use Watco natural finish on most of my turnings. I don't like shiney finishes. Or finishes that cover up the feel of the wood.
With Watco there is no problem with finger prints in your finish.
