200+ woodworking book reviews
Playing with detail gouges
Jorge
I have fun using my 5/8", 1/2" and 3/8" Doug Thompson detail gouges, there are great to shape the outside of vessels and other things as well:
The bigger one lets me reach far from the tool rest, and all 3 are good at following a curve, and to go back ant take up where last cut did stop.
I have not measured this vase, something like 13" tall and 9" at it's widest, looks massive, but I am pleased with the shape. Spalted red maple.
Re: Playing with detail gouges
Leo Cuellar
Leo Cuellar
Very nice, Jorge. I really love those curves!!! It flows nicely.
I made one similar but smaller back when I first started turning. Mine was spalted big leaf maple. I had to leave an ogee shaped foot on it & I couldn't really hollow it either as it needed some serious weight at the bottom as it had to hold a couple of glass roses from a local artist.
Jorge
Leo,
In all my vases, the bottom 3rd gets progressively thicker and ends with a thick bottom, to give them stability. Long things can overpower them, so I tried to give them a better chance. Thin even thickness, is nice in Johaness hats, but totally useless for pieces that are going to be used and abused.
Brad Vietje
Brad Vietje
Hi Jorge,
Nice shape! I hope we can see it when its done.
Looks to be turned right on the pith (?) If so, can you share your process? Do you drill it out? Rough turn -- air dry -- finish turn later? If not, please correct my bad assumption.
I have some spalted Red Maple logs that could become firewood, but if I decide to turn them, I don't have to split and stack em!
Safe spinning,
Brad Vietje
Newbury, VT
Jorge
Thanks Brad,
I rough turn if the pith is right on I turn around it, if not I put the center were it makes best use of the chunk.
Sometimes I let it dry after rough turning and if it did not split, saturate with CA glue and finish turn it, If it did split, drill out enough to get rid of it and usually make a plug of contrasting wood, although sometimes I make the plug of the same wood and try to make it invisible.
It is fun both ways
