Box Elder ornaments
spent a few more minutes on the Sphere Jig this morning and turned the round ornament. I made another ornament out of what was left with the blank.
Box Elder ornaments
Re: Box Elder ornaments
Those are beauties John.
I have been making ornaments for a Craft Show. Bill Turpin said they need to be under an ounce and a half. I weighed mine and they are closer to a half ounce. they were so light I questioned the little scales I am weighing the on. So much so that I looked up the weight of a quarter and used those to check the scales. The scales are right on. (I should have known, I borrowed them from the local drug dealer and his life depends on their accuracy.)
So now I am wondering if mine are too small. Mine are about 6" tall and 1 3/4" in diameter. What size are yours? Do you weigh them?
The balls on mine usually run about 2" give or take a little. Overall ornament between 5 and 7" I'd say. I read the oz recommendation on time so I do measure them occasionally just to see. I found out that even the "fat" ones that I don't thin very much are still under the 1 1/2 oz. I like to turn them thin because the customers are always shocked when they pick them up. Those usually weight around 1/2 oz or less.
I've been on a roll lately and had several that weigh 14 to 16 grams which is under 1/2 oz. The round ornament was left solid just to see. It's a little over 2" and weights 1.7oz.
Using exotic woods makes them weight a lot more so when I'm doing a production run I'll hollow the light woods quickly and not very thin. In fact I don't even measure the wall thickness I just turn them. They are fairly light as is. On exotic wood ornaments I pay more attention to the hollowing because it's harder to get them to feel really light.
josh bowman
John, those look great. You're getting good with the ball jig. I'm guessing you can leave a to
Tenon if you want to so you could hollow it??
Josh Yea you can easily leave a tenon. In fact you always leave a tenon and then rotate the sphere and turn it away later so you could just remove the tailstock, use the jig to round off that part, then drill a hole and hollow. Then use the jig to make the tenon smaller and finally cut it off. Place it between the cup centers and turn away the last tenon.
I also saw a really cool chuck a guy made that would hold the sphere with tenons on both ends. Then you can turn the tenons into smaller finials or icycles if you will. I thought that was pretty cool and may try to build one of those chucks. It was a cylinder that was coursely threaded on the outside and had a sort of cut center on the inside with a hole in the middle. Then there was a sort of cap that screwed on the cylinder that also had a cup center with a hole. You place the sphere in there and screw the two together until the sphere is captured with the tenon sticking out. Use the tailstock to align it. Then turn the tenon into a finial. Reverse and do the other side.
I bought some PVC threaded pieces to see if I can duplicate that device on the cheap.
Bob Rogne
John When you get it figured out show us a picture.
It would be a great idea.
Bob
