Any one own a LatheHamster *LINK*
http://www.lathehamster.com/
Re: Any one own a LatheHamster *LINK*
Re:LatheHamster
Bill has been developing the control for several years. You need to check your VFD to make sure it's compatible (won't work on my Stubby). Bill has put together a nice control unit but I prefer a simple on/off box for a remote and I just don't need to know what the RPMs are to the double digits.
Josh Bowman
Tell me how this helps? I can program the accel and decel on my Delta and Teco VFD's without the little box. Not certain I need to do it on the fly. I have my metal lathes programmed that way to keep the big chuck from spinning off on my foot.
Jesper, Denmark
Re: No, but.....
Jesper, Denmark
The 15 year old VFD on the General has been performing without a hitch for 20 years. It's a Square D Altivar 18, hidden in a box on the back of the lathe. Control is by a simple rheostat with no read-out of speed.
It was easy to re-program for 50 Hertz operation.
I have not felt any need to alter the acceleration/deceleration settings, but they can be re-programed on the unit, which even has an honest-to-goodness manual.
Only complaint is that if overloaded, it takes unplugging the lathe and waiting for "a while" before it can be re-started.
No fancy gizmo's - it just basically works.
Would be like my microwave oven
Bill Howatt
My microwave has all sorts of clever settings but it only gets used in 1 mode 90% of the time and a second mode the other 10%.
Given that it communicates with and uses the functions of your existing VFD, you probably could program the "improved" settings and leave it at that. I don't really see changing them on the fly especially when it is up to the operator's good sense not to brake or accelerate too fast.
I'll spend my $200 on something else.
Bill
David Propst
I've been talking with Bill about replacing the VFD on my Poolewood with a new VFD and a LatheHamster. The OEM VFD on mine is a big clunky 14x 11" box that was meant to be on a floor stand. I've never figured out a permanent place for it that is not in the way. It has been acting up lately and replacing it looks like the best option. Adding the tethered remote will be really nice. Probably will order one in November.
Of course after turning on the American Beauty at Arrowmont twice now my lathe seems kind of dinky. Not in power, but in fit, finish, and design. Need to go check my lottery ticket...
David
Re:LatheHamster
Don Orr
Curious that it won't work on a Stubby when it was designed by the Stubby dealer. Hmmmm.
Dick Hines
Dick Hines
When I went to the link I expected to see a little fuzzy critter in a cage with a belt attached to a lathe that could be taken any place.
Fuzzy critter = no power requirement.
Re:LatheHamster
My lathe uses the original Eurotherm VFD installed by Omega. Not compatible with Bill's hamster which is configured for the C/H and Delta units only. If my drive goes bad, I would get a C/H replacement, but 'till then I'm fine with what I have.
Steve Worcester.
The hamster can do much more than accel and deccel on the fly thought. In fact so many things you have to talk to Bill about their benefits.
One of the reasons for the compatibility too is does the Hamster bypass the emergency switch. That's pretty important from a designer liability perspective.
Joe Fleming
Re: LatheHamster - the back story
Joe Fleming
For the non-Stubby folks here, a bit history. When John Jordan was the importer of the Stubby, the controller in the unit from Australia was a Eurotherm. Those of us with Stubby's of that vintage received that controller. When Bill Rubenstein took over the importer's role, he took John's orginal and made some modifications. One was the controller. The Eurotherms are OK, but not the best controller. To save some cost and improve design flexibility, Bill when to the new controller. The best advantage (maybe) that the eurotherm had was its size. It could fit inside the base of the S750 model. The new VFD cannot fit in that same cavity under the headstock.
I've already had one Eurotherm go out several years ago, requiring replacement. This was before Bill hung out his shingle. If the current Eurotherm goes, I'm switching to the new VFD.
As for the name "LatheHamster", Bill held a naming contest on the Stubby User's Group blog and someone came up with that name.
The "LatheHamster" has some benefits about which you can discuss with Bill. I know that Bill has come up with a number of modifications over the years and the ones I purchased have been well done and reasonably priced.
Joe Fleming
San Diego
