Sphere Turning Jig *LINK*
A friend purchased one of the sphere turning jigs and asked if I could play with it and learn the finer details and show her how to use it. I'm having a ball (pun intended) and have really just started. It is the Sphereturning jig. Not inexpensive but built really really well. Very solid with bearings for movement. I'll write up a review in a week or so when I've really run it through the ringer. So far quite impressed.
I had a friend come over yesterday. He's been trying out some other sphere jigs and trying to make very specific sized sphere for a marketing project he has in mind. Was only able to get within 1/64" of the correct size with the less expensive jig. We turned one yesterday within .010" of dead on size wise and roundness around .003 to .005" That's pretty darn close and the finish off the Hunter tool was easily sanded with 220.
The 3 spheres were the first ones turned and are within 3mm of exactly the same size. They are a little more out of round because I used a manual method to turn the tenons off and got them off a little. the Hackberry sphere was turned using a slightly different method and only had one tenon to turn off and I got it much closer as you saw by the numbers. Will try a different technique today even though the last one worked mighty fine.
I have a lot more experimenting to do. It will hollow spheres also so that's the next project to learn more about it.
http://www.sphereturning.com/
Re: Sphere Turning Jig *LINK*
John Stegall
Looks good John. Their site says production has been taken over by Carter Products, the bandsaw jig folks. The link they supplied was broken but a quick Google search turned them up. At Carter's website click on lathe accessories.
John
