Walnut bowl
Walnut bowl
Walnut bowl
I was walking through the shop looking for wood to turn some more spheres and this bowl just yelled out at me. Seriously, it is a really odd shaped piece of wood a club member gave me years ago. Never knew what to do with it. The I just saw it and knew what it should be. Don't know if the wood talked to me but how else do you explain it.
I left the outer edges more or less the way they were. I gave them more angle and a slight curve. Then textured them. The top was flat so I left it that way just cleaned it up a little.
Finished with 4 coats of Minwax wipe on Poly that was steel wooled out then buffed with the bealle buffing system.
Re: Walnut bowl
That's really nice, John...
GaryG in MD
I love the shape, and also the hole in the side.
Well done! ...GG
Re: Walnut bowl
Alan Sweet
Nice,,
Alan Sweet
Curious question.
How did you turn the bottom?
Re: Walnut bowl
Re: Nice,,
John lucas
Mounted between centers as always then turned the bottom with a tenon. Then turned the inside. Then turned the foot using my tailstock and a 3" vacuum chuck. Could have. Turned it with my rubber jar lid opener over my chuck but the vacuum chuck was easier
