Wild Apple turned to completion
Mike Brazeau
There were some questions a couple of weeks ago about turning to completion. Here are a couple of pieces of wild apple I turned during the summer. The tree came down in a spring ice storm. Bowl is about ten inches in diameter with walls 1/4" to 5/16". Both were sanded wet progressively from 80 to 400 and were drenched with Watco Danish Oil and allowed to dry for 2-3 weeks before polishing with tripoli and waxing with Conservators Wax and buffing. Took about ten days to dry to constant weight and the finish probably took equivalent time to really dry. The Pencil Pot is about 5" high and a bit over 4" in diameter and came from a small limb section. Great contrast of heartwood & sapwood. Before buffing, the surface was slightly rough from the drying process, but buffed up to a really nice satin finish. Bowl brought $75 at a silent auction for my Grandson's AA Minor Atom Hockey Team. Pot goes to our daughter as a memory of their tree.
Re: Wild Apple turned to completion
Brad Vietje
Brad Vietje
Nice job with the live edge and very nice color, Mike.
Oddly enough, I was just writing to a spoon carver from Wales about using and handling green Apple wood when your post popped up -- small world!
Safe spinning,
Brad Vietje
Newbury, VT
Dan Jechura
Dan Jechura
Love apple wood. Good job!
Dan
Sergio
I like your bowl.
I tried many times to turn apple wood but had always problems with checks and cracks and an enormous movement of the wood.
Did you have any of these problems?
both very nice, Mike...
GaryG in MD
I love the way it smells! ...GG
Outstanding!
Re: Wild Apple turned to completion *LINK*
Mike Brazeau
The pot has significant warping but since it has a natural edge, and it is a whimsical piece (pencil pot) doesn't really matter. The centre of the endgrain heartwood,which I hardened with CA, sticks out significantly if you look at it in profile. When I photographed it didn't really show. I want to try a very thin shallow bowl with a conventional edge and just let it deform. The natural edge bowl looks fine as from the top you cannot see the effect as much. In mid June I tried the normal rough out process for a natural edge and it cracked in the end grain and then I decided to try turning to completion. I can likely fill the crack, perhaps with an accent like turquoise. Was really the first time I tried anything serious turning to completion and am pleased with the results. Have to get back to it before the wood starts to discolour. I still have about four feet of trunk wood.
The Joy of Wood
