yeah, I think I can?
steven antonucci
So, in a nutshell, edges are ALWAYS sawtoothed because of the way that turners will typically get them (rotary wheel).
The 80 grit wheel will leave 80 "teeth" in an area that a 1000 grit wheel will leave 1000 "teeth". If you break 10 teeth, it is a lot worse than if I break 10 teeth. I don't think you'd dispute that, but I know where you'd go next... that the smaller teeth are much more likely to break, right? Let's test that theory with almost any material?
Metal structure is typically composed of lattices of iron with carbon in the voids to keep the structure from deforming. A larger tooth (i.e. 12.5X the size) will see torque forces 12.5X greater than a smaller tooth because the tooth is longer. Even though it is at a microscopic level, it is still 12.5X. Under these forces, it is more likely to break an 80 grit edge than a 1000 grit edge.
However, you probably don't notice it as much because the 80 grit edge isn't all that sharp anyhow. As it degrades, it loses "teeth", mimicking the effect of only having 60 teeth from a 60 grit wheel (albeit not the exact same thing, since the spots where teeth broke away are no longer sharp at all).
I can tell you that you'll get a similar effect from the Tormek graded to 220 or 1000, with the loss of "teeth" over time being much more noticeable because the edge WAS so much better when it started, but a dull Tormek ground gouge will still be much sharper than a dull 80 grit wheel ground gouge because the fractures are much smaller. When you lose a "tooth" that is 12.5X the size of the Tormek tooth, you leave behind a much larger blunt edge. Add to the overall discussion that any dry grinding wheel is also heating the metal up, which reduces it's strength, meaning more fractures are likely... and you've got Metallurgy 101.
You are certainly entitled to disagree with me, but I am not wrong.
Steve
