Help with lathe jaws
Marty
I need some help! I was putting on a set of "C" series wide jaws, on my Barricuda 2. I needed "just a little more of an opening" I turned it and (all), one at a time, the jaws fell out.(opps.) I have been trying for over an hour to get then back on,that is not the problem. They will go on, but not as to be centered together. What must I do besides purchase a new Barricuda "C" series chuck. Thanks, Marty
Re: Help with lathe jaws
Philip Duffy
Marty, Look for a number on each jaw. They must go on in sequence. With the jaws all off the chuck and lying in a row turn the chuck until you see the first opening of the track-spiral. Insert the nr 1 jaw and turn the chuck until the second opening of the spiral track shows up, then insert nr 2 jaw. -- - etc, etc. When you have all 4 jaws mounted close it up and it should look tight at the center. If you can not find a number on each jaw then try scrubbing them with a wire brush on all sides. Some chuck-jaws, ie, Nova, are very difficult to find. -- Good luck and let us all know how you make out on this challenge! pHIL
Marty
Thank You, Philip. I turned the little black thing'ys that go in and out,and much to my surprise,one of them had Six,lands, one had Five lands,the other two had four ea. So I started wirh the six and worked my way around,a perfict fit. I was in a dead panic as I am almost done with my Christmas gifts,this was one of the last. Thank You again,next time I'll look for the numbers LOL, Marty
Chuck maintenance
robo hippy
This is a link to the first of Ian 'Robbo' Robinson's latest series of You Tube clips on how to maintain take apart your chuck, and put it back together. Also check out his safety clips. If you don't know who he is, he did the one where he gets a bloody finger when demonstrating how NOT to use a spindle roughing gouge on bowl stock. The chuck clips should help you get your chuck back together. Excellent clips.
http://www.youtube.com/watch?v=JsAwkLyRSbM
robo hippy
Mike Peace
Re: Chuck maintenance
Mike Peace
You can also download detailed instructions from Teknatool if you want a written reference http://www.teknatool.com/support/Chuck%20Support%20Page.htm
After watching Ian's videos I am motivated to take my SN2 apart for cleaning and re-lubing. Is there a better recommendation on grease than that provided by Teknatool? "...be very generous with the grease application. (Normal multipurpose grease is sufficient)".
Harry Robinette
Harry Robinette
The only lube that goes in or on all my chucks is PG2000 spray.I do all my chucks twice a year, torn down,cleaned and lubed then reassembled.It's been working for a few years now. I have all Nova chucks from the Titan to the no longer Compact.
I haven't had a slide stick and no jams sence I been doing this.
Just my way keeping them working.
tomB
I use Dri-slide on my chucks. It is graphite and molybdenum. It is messy when you put it on, but the solvent evaporates, and you have nothing on it which will attract sawdust and turn it into gum. The best place to get it is at a bicycle shop
Very concerned
Geoff Whaling
Marty, heaps of good advice on the reassembly of the jaws.
I'm very concerned that nobody has picked up on your comment "I needed "just a little more of an opening" I turned it and (all), one at a time, the jaws fell out.(opps.) ".
Chucks have a safe operating range i.e. the opening of the jaws. Unlike scroll chucks used in metal turning most four jaw woodturning scroll chucks have some form of stop feature, either a pin set into the chuck body or a cast section on one backing slide itself to prevent just what happened to you. I’m not familiar with the Barracuda chuck so I do not know what safety feature they use. Their manual is not very helpful at all, and offers no information of safe operating range for the jaws or the maximum recommended work piece etc. It does offer recommended speeds though.
If you are opening the jaws so wide that the backing slides are disengaging or near disengaging from the scroll then you are operating in very very dangerous territory! Flying objects coming off the lathe do kill wood turners.
All that holds the jaws against the significant centrifugal forces is the lands on the backing slides engaging the material on the scroll. At least one full "rotation" of the scroll must engage all backing jaws to at minimum retain all of the backing and top jaws in place. Then there should be sufficient engagement to prevent damage to both the backing jaws and the scroll due to metal fatigue / stress both from the tightening of the jaws against the work piece, and the typical forces encountered while turning the piece.
Please for your own safety check out Robbo's clips as they will give you a good grounding on the basics of how chucks function and how to look after them.
