REAL MILK PAINT
New lathe
New lathe
Dick Hines
New lathe
Dick Hines
It is not for me. A friend a Delta 14-42 on the internet for $550 with a set of Sorby tools. It look like it has little or no use,
I know nothing about this lathe. Does sound like a deal or not?
Re: New lathe
Re: New lathe
John Veerkamp
I had one for 12 years before I upgraded to a PM. It was a good serviceable lathe and well worth the money. The older 110 models had problems with the electronic controller. I had to replace mine after about 10 years. The replacement form Delta was very pricey, but a 220 Baldor( the maker of Delta's controller) from an electrical supply was much cheaper. I had to modify the motor wireing but it was a piece of cake. $550 is a reasonable price depending on it's condition otherwise.
Re: New lathe
Re: New lathe
I'd check the headstock castings for cracks, only because I knew a guy who bought one and found out too late that there was a crack. Others will have to weigh in on other concerns.
Re: New lathe
Re: New lathe
Greg Haugen
Dick,
The main issue I see is that it's a discontinued lathe from a company that has been going through some major changes and has been dropping a lot of products. Parts will be difficult to find and the Reeves drive will need them at some point. I'd recommend one of the newer midi lathes, any of the current manufacturers. He may spend a little bit more but in the long run, he'll be ahead. He could buy it and potentially a month from now have nothing more than scrap metal if something breaks.
That model lathe was my first.
Re: New lathe
Dick Hines
Re: New Information Just In 46-715
Dick Hines
I got a message from my friend that he has found out the lathe is a 46-715 model. I still don't know anything about this lathe.
Any information would be helpful.
Re: New lathe
Re: New lathe
Cyril Griesbach
Dick,
I think the 46-715 may have also been known as a 1442 long bed at one time. The 715 was my first lathe and it was adequate for me as a beginning turner. I don't believe it is being produced any longer so prior comments on service and parts availability may be spot on. I've also turned on the Jet version of this lathe which also has a Reeves drive and can say that in my experience the Delta was more than twice as noisy as the Jet. I think I'd back away at that price unless the tools can be valued at about half the total cost.
Re: New lathe
Better known as the Delta Ironbed
Greg Haugen
This was the model of my first lathe. Reeves drives lathes are a starting point but that's a hefty price for a lathe with little to no service and a problematic Reeves drive. The Reeves isn't a bad system but there's a lot of mechanical moving parts, a lot can go wrong and they wear out more than other systems.
http://www.amazon.com/DELTA-46-715-4-Horsepower-Woodworking-120-Volt/dp/B00005V5NM/ref=cm_cr_pr_pb_t/185-3724858-3230467
