Turning in Reverse
Turning in Reverse
Turning in Reverse
I know some people do hollowing with the lathe running in reverse. Does anyone turn the inside of a bowl with the lathe in reverse? I have turned about twenty bowls in the last week or so and was wondering if some of it would not be easier with the lathe running backwards.
Re: Turning in Reverse
Chuck Engstrom
Hi Barry-- I've turned in reverse inside bowls a couple of time but haven't adopted it as standard procedure. It seemed to help with my shoulder problems (right shoulder was replaced five years ago) to some extent but it's not a cure-all. In most cases I found myself going back and forth forward/reverse depending on where I was inside the bowl. But it was never any real problem, just takes a little getting used to. I certainly think it's worth investigating.
Give it a try and let us know what you think. -- Chuck
No reason it can't be done in.......
JamieDonaldson
...reverse with some practice, but the mount and blank will unscrew from the spindle unless it is secured in some way. :b
Jim Breeden
I turn in reverse about 50% of the time, primarily to see into the item I am turning, as my lathe is not set for me to be able to move to the other side.
Brad Vietje
Brad Vietje
Turning in reverse is essentially what is done when turning outboard on a non-reversing lathe -- has been done with success for generations. As Jim alludes, instead of reversing the direction of the rotation, you can also move to the other side of the bed if your set-up allows, which can help with posture and visibility issues.
Safe spinning,
Brad Vietje
Newbury, VT
Bill Howatt
Moving to the other side of the bed eliminates the chuck/faceplate unscrewing problem which should not be ignored.
Bill
Alan Sweet
Alan Sweet
I like the sanding finish I get when sanding in both forward and reverse.
I just couldn't hold the gouge properly behind my
back. Also couldn't see what I was doing. I'll stick to turning forward. :)
Steven Antonucci
Just hold it flute down instead on the left side
Leo Cuellar
Leo Cuellar
I've done it a few times to clean up the edges of pieces with voids in the walls. Sometimes i get a little ridge on the trailing edge, probably because I'm putting a little to much pressure on the cut. It did help save effort with not having to do as much sanding.
Re: I just couldn't hold the gouge properly behind
Dale Miner
If the lathe was running in reverse, wouldn't the shavings go back together and fill the bowl back up? ;)
There is no mention of such a wood.......
JamieDonaldson
...saving potential in the instruction books Dale! :D
Re: There is no mention of such a wood.......
Dale Miner
Darn. I was hoping for a way to undo those early shapes and recut to one more better.
