Mirror repair
Mirror repair
Mirror repair
Once in a while I have a problem with the mirror opening getting too large. Lots of reasons, wood chipping and you have to cut more or you make a bad cut or you simply cut it too large. I have repaired them by adding rings from another piece of wood but that wastes a lot of wood.
In this case I mixed up some thickened epoxy. Added some brown and black paint to make a darker brown. The poured it on and let it harden. Cut it back after dry and you have a repair.
Re: Mirror repair
Leo Cuellar
Re: Mirror repair
Leo Cuellar
Nice save, John. Now if you can figure out a way to add some some copper or brass, you could break into the steampunk market as well.
Re: Mirror repair
Bill Blasic
Re: Mirror repair
Bill Blasic
I'll bet that brass powder mixed with epoxy would work.
Bill
Re: Mirror repair
"If a mistake can be fixed, it didn't happen."
Re: Mirror repair
Re: Mirror repair
Bill I haven't been a fan of the metal powders. They just don't have the gleam of real metal and look fake to me. I like metal chunks stired into epoxy but it's hard to find them. I tried making them taking course cuts on my milling machine and then trying to break them up but that didn't work real well. It would be great if we could find them in sizes similar to the plastic chunks the Inlace sells.
A short story about making my own powdered metal. When I was doing the tips pages for American Woodturner a guy sent in a tip about grinding copper pipe on a disc sander to produce your own powdered copper. Sounded cool so I went to the shop and grabbed a section of pipe and proceeded to grind the end to produce the powder, cool, it works great. Then the heat hit my hand and I threw the copper across the shop. Man that heat travels fast. It was a foot long piece and ill bet the end I had in my hand heated up in about 3 seconds.
Re: Mirror repair
Re: Mirror repair
Stuart Johnson
To quote Martha Pullen (sewing expert, teacher, professional optimist ):
"There is no such thing as mistakes, there's only design opportunities."
Re: Mirror repair
Source for metal filings....
Find somebody with a key machine and get the filings from them. they are mix of brass and whatever the silver part is. Be careful though, they are extraordinarily sharp and will stick in your skin like the worst splinters ever. Wear eye protection.
Good looking Repair. Saved a few trees. How many Epoxies had to die for this?
Re: Mirror repair
Stuart, that saying has been in .........
JamieDonaldson
...common use by turners for many years, but I wonder who was actually the first author?
