Could simply be your tools are too large. I use 3/16 " cutters. You can feel drag with them when they are dull however when sharp they cut with very little pressure
The cutters must be parallel to the floor and on or above centerline slightly while in scraping mode. Right-on John, smaller cutters work better, easier.
It can be done a bunch of different ways. Some times it is easier, especially before you really have the hang of the tools, to drill out the center, then hollow out the rest. Getting the dead center part cut isn't easy. It can be done with gouges, but for end grain, the hollowing tools are easier for me to use.
Be sure to clean out the vessel often as you hollow. Especially at first. Too many chips and it will drag around the cutter and mess up the cutting. Shut off the lathe and use compressed air OFTEN! You will have the lathe shut off more than cutting at the start. Then you get a little more done and you can cut a slight amount longer.
Not sure what you mean by drag. You may be trying to cut too aggressively which could be the result of too large of cutters as John and Lyle have said. You could also try using a different type of cutter/scraper with a more straight-on approach and take lighter cuts to see if that helps.
My first reaction was that you might need to remove shavings/cuttings more frequently. They can certainly make hollowing more of a trial. If you are removing the shavings before they take up a fair space, then tool use is more likely the problem.
A few ideas for anyone new to hollow form turning:
1. Practice on a piece of end grain where you can see what's happening. You can mount a chunk of a log on a faceplate or chuck and start messing with the cutters to get the feel of how to use them efficiently.
2. Move the rest back a little at a time to simulate cutting at the depth/overhang you desire to make.
3. You can even add a simulated small opening by clamping a piece of scrap to the tool rest with a hole in it -- can also help you develop a "feel" for blind turning.
4. Progress from flat end grain through a bowl, to a closed bowl form, to a hollow form in stages as you feel comfortable. At each stage you will be working in a more constricted space with more limited vision.
5. Stick to end grain vessels at first, cutting from center outward. You get less vibration in the turning, and you are more likely to get chips or crumbs, and not shavings -- which you do not want. Wet shavings tend to form wood felt, and can suddenly bind up the tool if you aren't stopping to clean out the vessel often enough. When switching to side-grain HF's, remember the grain direction changes, so the direction of the smoothest cut changes, too.
6. Remember, you are cutting across the end grain, in multiple small steps to the side, from right to left in normal rotation, not cutting into the end grain.
7. If you do end up poking a cutter into end grain, you will find your tool trying to cut from left, right, and the tip all at once, so you will get a huge increase in downward force to overcome. Best to try this on an end grain slab so you can see what I mean.
8. Swan neck or goose neck tools should be supported with the rest under the straight part of the shaft ONLY.
9. For practice pieces, try drilling a few big holes in the side of the vessel before you start hollowing. The chips and shavings will come out as the piece spins, and you can see the wall thickness as it develops, and if you get the lighting right, you can also see the tool as it cuts -- very helpful for understanding what's happening in there.
Most hollowing tools are 3/16 as a compromise between smaller (more aggressive, less cutting force) and larger (more force to cut). Larger tools, like your 10 mm round carbide, or the 3/8" bullet tips from Sorby, are useful for smoothing the ridges left behind by smaller tools, but less useful for hogging out material.
