Re: buffing ca
David Walser
Darrin - It's hard to tell whether the problem is with your buffing or with the CA finish. CA finish, when applied improperly, can have small voids below the surface. So, your Tripoli buffing could lower the surface of the CA just enough to reveal those voids. However, it's hard to imagine that your sanding would NOT reveal any voids and your buffing would. Possible, but unlikely.
More likely, is that the heat from buffing was too great -- particularly if portions of the CA was not fully cured beneath the surface. When buffing CA, I use a lower speed, a lighter hand, and a finer compound (Don Pencil's PL compound). This approach has worked well for me. Using Tripoli, higher speeds, and too heavy a hand, sometimes left the finish with visible streaks.
I usually don't buff CA anymore. I've found going through all the grits with micro mesh and using a liquid buffing compound from the automotive parts store works just as well and is much faster. Everything's done on the lathe.
I also wet sand the CA finish starting with 320grit. It keeps the heat and dust down. Frankly, once I'm through with the last grit of micro mesh, I don't know that I need to use the polishing compound. Micro mesh is made for polishing the windshields on aircraft. If the scratch pattern is so fine that it leaves a finish good enough for a windshield, I doubt a liquid polish from the auto parts store is going to improve the finish much. I use it because I saw someone at a demo use it and because I have it.
Good luck!
