I have a DVR I bought at WoodCraft about 11 years ago. I just blew compressed air through the head stock thinking it was good to clean it out occasionally. Now it says Fault and on the next line RP State Error 0. Then it plays the error music and reverts to Ready to start at XXXX. What do I do to correct this error?
I have sent the same E-Mail to Teknatool. I Am betting Wood Central comes through First.
1 Unplug the lathe press the start button often the motor will turn using the energy stored in the lathe capacitors.
2 Remove the hand wheel it is left hand threaded.
3 Remove the red cover.
4 Remove the index wheel.
5 On the shaft you will find a tooth sheet metal wheel see photo.
6 Clean optical sensors see photo. With a Q tip and water or air. Do not use any solvent as they can fog the lens.
7 Resemble and test.
The optical sensor works by sending 2 beams of light across the gap and detecting it on the other side. The wheel blocks the light interment as the shaft turns. The board counts the blockages and there timing to the speed and direction the shaft is moving.
I found the page Mark posted by going through Google. Astounding to me that putting Error state 0 into Google got it in nothing flat and about the fifth one down.
I looked through the Teknatool site for info on Error states and did not find it. Did not think to look in Frequently Asked Questions.
Turns out that mine is different than shown in the pictures. Mine has a fine mesh metal screen similar to window screen glued into the end behind the indexing plate with what appears to be silicon. I pealed the bottom of that loose and blew out the compartment behind it. (Did not have the crescent shaped metal cover plate shown.) I checked and the lathe went back to work, so I did not go further.
The sheet you posted and your posts gave me the courage to open it up and fix it without too much fear of letting the puff out. Thanks to both of you.
