Flashlight Lit Exhibit Idea
charlie belden
I've always been bothered by the fact that the process of turning is so dynamic, yet the end result is almost always static. Our source of wood, trees, aren't static. They change size, sometimes color, sometimes have leaves and sometimes not, they move in a breeze and bend a bit in a gust. Why should a piece of a tree that moved when alive, be so still when we make something of it?
Having gotten quite interested in 3D printers and how they are put together, I've gotten back into playing with small, battery powered, programmable micro controllers and things to control with them - like stepper motors to control the location of the Extruder 3D printers use to "print" things. And while searching for info - I stumbled on a simple Light Tracker. Shine a light in the general direction of the Tracker's "eye" and the "eye" will turn towards the light.
Now imagine a very dimly lit exhibit of turnings, and vistors are each given a small LED flashlight at the door - but no explanation as to why.
You, as a visitor, can see a piece that interests you - and you shine your flashlight at it. The piece turns - to face you! You move in for a closer look - the piece still facing you. You move around the piece, wanting to see the back of the piece. But the "face" just follows you. Eventually you figure out that if you shine your flalshlight straight down on the piece it stops following you and you can check out the back - and sides.
This idea would use two little Light Dependent Resistors (in bright light NO resistance, in darkness 20k to 30K ohms of resistance) - one on the Left and one of the Right of the "face" of the piece - and a small servo to provide the movement of the piece. The "sensors" acting as an "eye", the servo acting as the "muscles" to move the "eye"
Flashlights in a darkened room would be unusual - and some folks would probaby pocket their flashlight ; ) But there are also electronic "sensor" that can detect very small differences in temperature, changes in reflections of infra red light and even ultra sonic "radar" detectors that can sense not only movement, but distance to the moving object as well. The latter is a bit large (1" x 3") so harder to hide in a piece, though incorporatable in a pedestal.
The idea of pieces interacting with viewers is an intriquing one.
Have YOU any ideas for providing ways to have people and pieces interact?
