for John Lucas: coloring epoxy
GaryG in MD
Hi John,
I thought I'd move our WoW discussion about coloring epoxy over here for everyone's benefit.
To bring others up to speed:
In your reply, you noted that water-based inks and dyes work OK in epoxy even though some warn not to do it. You also noted that oil-based colors will work.
You also noted that powders (like tempra and ground materials such as powdered chalk) CAN cause problems. When you say that you use "slow set", what exactly do you mean by that? I assumed that "15-minute" would be long enough to get the job done. Do you agree, or not?
Have you ever tried acrylic artists colors (paints) straight out of the tube into epoxy? Seems like that would also be a good solution.
Have you tried alcohol-based dyes? They might be too thin...
TIA, Gary
Re: for John Lucas: coloring epoxy
Beth Ireland
Jorge
does or did use colored epoxy extensively, she used the slow set epoxy (overnight) and used alcohol dyes and got very good results.
thanks Jorge...
GaryG in MD
I'm hoping I don't have to reconsider my purchase of 15-minute epoxy, but that's one of the things I hope to find out from this post. ...GG
don stephan
On more than one occasion I have used 5min epoxy to file a crack, worm hole, missing small knot, et cetera - snall defects. I use "fresco" powders which I think are simply ground pigment. Almost every time I have used black powder.
barry rockwell
barry rockwell
I've used colors extensively in both epoxy and cyanoacrylate glue, and whether it's 5 minute, 15 minute, or overnight epoxy, I have used Trans-Tint dyes for translucent colors and liquid epoxy pigment for opaque colors. I have done fairly large pours of epoxy, but small amounts of CA for small cracks. It tends to make the CA go off pretty quick.
Thanks, Don...
GaryG in MD
The "Fresco" powders are usually tempera.
That's good to know.
Thanks, GG
Thanks, Barry...
GaryG in MD
Well, that's a "duh" for me!
I hadn't looked up "epoxy pigments".
There they are! Very good to know.
Thanks, Gary
Bill Blasic
Bill Blasic
When I took a class with Marilyn Campbell she used oil paint as a coloring medium. She said not to use Acrylic paint. And I believe that we used a 15 minute epoxy (working time). Worked well enough that I bought the epoxy, the pumpers, the filler and oil paints.
Bill
matt overton
Marilyn Campbell uses West System epoxy with artist oils and the filler from West Systems
Bill Blasic
Bill Blasic
Matt,
Exactly what I purchased.
Bill
Bill and Matt...
GaryG in MD
Thanks for your info.
If anyone should know, it's Marilyn.
I've got lots of old tubes of oil paints laying around, so that's a good solution for me. I'm also glad to hear that the 15-minute epoxy I bought is satisfactory (as long as I'm quick enough!). Now I can play... ...GG
Joe Fleming
Joe Fleming
I use TransTint powder dyes in 5 minute epoxy all the time. Works grat. No impact to curing time or strength. Joe
Carful of the dust
Jim H
At SWAT, Marilyn said to be very carful of the dust from oil paint colored epoxy. She said that a lot of the pigments were bad stuff if inhaled. She even puts on her respirator to sweep.
John lucas
Gary sorry it took so long to reply. Been in Rochester NY doing a demo. My phone is so slow. Been using water based pai tx for years with west system epoxy. No problem. I prefer using inks or dyes. I use mostly west system 5 minute or the slow set which takes over night. Marylin also said not to mix Weat System using weight. Spry but been doing that for years also with no problem
very good point...
GaryG in MD
...and well taken!
As defacto Safety Officer in my club, I've just been harping about the dangers of wood dust and proper remediation! ...GG
another good data point!
thanks, John...
GaryG in MD
Hope your demo went well.
Sounds like most coloring agents will work if used thoughtfully.
So many choices! I'm not sure which one I'll try first, but I'll post the result.
...GG
John lucas
Epoxies are all just a little different. Some colorants won't work with some epoxies. Always run a test. I mix epoxy in Dixie cups and Eden on formulas that I know work ill leave the leftover in the cup and check it in an hour or so to see if it hardens correctly. That verifies that my mix was accurate and whatever I put in didnt adversely affect the stuff.
I mix using digital scales. Put in part A. Weigh do the math a d add part B until it weighs what the math said. Mix in color or thickener or both and stir like crazy. That's part of why I use the slow hardener a for many things it takes time to really get a good mix.
Jesper, Denmark
Jesper, Denmark
Any kind of dry powdered pigment should work OK with epoxy. I use graphite for making it black. Epoxy can be thinned with acetone or alcohol, so any dye based on alcohol would also be OK. I would be wary of water or oil based product, as I do not know how they would effect the epoxy reaction.
Be careful when selecting a thickener to control the viscosity. I used the West high density stuff once - bad idea. The resulting set epoxy was very abrasive and darn near impossible to either cut or sand.
John lucas
The west system thickeners are for different purposes. They tell in their catalog which ones are softer. I use the 410 and 407 most often
Jim Evans
Re: for John Lucas: coloring epoxy *LINK*
Jim Evans
I use Pearl Ex powders, a little goes a long way. I haven't had any problems with 5 minute epoxy.
Pearl Ex
another good reco
GaryG in MD
Thanks, Jim. ...GG
