Veritas - Innovation in Tools
Anyone have a favorite finish for Holly?
Henry (Raleigh, NC)
I have a Holly bowl turned - subtle white and grey tones. I suspect that any of the regular oil finishes, or even shellac (SealCoat) will provide an amber tone. I will of course try a off cut before finishing the bowl. That brings to mind ol' M Dresdner's oft repeated phrase: Finish firewood first. Too often I have ignored that at my own peril.
So anyone have a favorite finish that keeps/enhances the color tone of holly (without making it appear amber)?
Henry
Re: Anyone have a favorite finish for Holly?
Lacquer is the answer!
Re:  what is this?
Sergio
sometimes I see Nm between asterisks. What does that refer to?
Re:  means "No Message"
robo hippy
I thought it meant No More. Close enough.
robo hippy
also...
GaryG in MD
If you don't like lacquer, you can also use water-based poly or a spray acrylic or just a matte fixitive. ...GG
Water based poly
Barbara Gill
I use a water thin water base poly. It soaks into the wood and is pretty quick drying. I knock back the fuzz with 600 grit and apply again, wiping off any that does not soak in. I sand with 600 again to knock off any shine and then wax the surface. The result is a flat finish that looks really good.
tomB
You can get a great finish on holly with micro mesh sanding. It will glow.
just the bare wood with nothing on it?
GaryG in MD
I would think that would be prone to getting dirty quite easily with any handling.
What's your experience, Tom? ...GG
Re: just the bare wood with nothing on it?
tomB
The finish will be silky smooth, and the grain is extremely fine, so dirt can easily be wiped off. I have not made utility pieces from Holly, so don't have experience of using it as a salad bowl
Understood; thanks, Tom
