Oneway tower jaws
Mavdad55
Has anyone tried these? With all the discussion about tennon vs recess, no one mentioned the use of oneway profile jaws. These have a larger range of safe contact when the tennon is larger than the closed size due to their shape. True they have teeth, but I would assume most folks finish the bottom of the tennon last which gives you a chance to remove the teeth marks.
Oneway now has tower jaws which have both the profile shape, for longer tenons and dovetail at the outside edge; for the type of holding you have all been discussing. So I was looking to see if anyone has tried these in both modes, profile and tennon. They also have the advantage of getting the wood farther away from the chuck body, making it easier to work on the backside.
