If I run the compressor, not really
steven antonucci
I usually charge it up to 90 PSI or so, and I can get through most of a grit without it running. If I am in a hurry, I just start it and sand with shooting muffs on to cut the noise down. It fills almost as fast as it depletes, so I can sand an entire 15" bowl in about 15 minutes to 220 grit.
It sits 5 feet from my lathe, so it's kind of loud, but manageable with hearing protection and has probably delivered a couple of hundred bowls over the 5 years or so that I have owned it. I switch the sander for a blower to blow out the grits in between, so it's kind of convenient to have it right there. I would lose the blower if I had to put it in another room.
My next compressor will be purchased based upon how loud it is when it runs, but for now... this works well.
Steve
