Broke Spindle lock shaft collar on PM 3520A
Tony Reynolds
Tony Reynolds
I doubt I'm the first to do this, but after coring 30+ 18" cherry bowl blanks my stronghold chuck was stuck on the lathe. In the process of freeing it I managed to break the pot metal shaft collar they use for the spindle lock on this lathe.
Has anyone come up with a different way of locking the shaft? The only other way I see is to have the spindle shaft bearings pressed off and replace the collar shaft. Not something I want to take the time to do right now.
Thanks,
Tony
Re: Broke Spindle lock shaft collar on PM 3520A
cranskin
My answer was to use a pipe wrench on the other side of the headstock . Crude but effective.
Dick Hines
Dick Hines
Just order an new spindle lock from PM.
Take the hand wheel off along with the star lock washer. Then loosen the set screws on the spindle shaft. Use a block of wood and a hammer to knock the shaft out. Put the new spindle lock on the shaft and reinstall. MAKE SURE you line up the pully with the motor pully. It should take you less that a a hour.
I will not tell how I know this.
Tony Reynolds
Tony Reynolds
Thanks Dick. When I have time I'll give it a go. Still can't believe I broke the collar in 3 pieces only using my hand / arm pulling on the chuck key. But the collar is only about 1/8" thick in the places it broke. It lasted 8 years, so I guess I can't complain to much.
Tony
Dick Hines
Dick Hines
Tony, it's cast not machined. I expect it's that way because some of use are heavy handed. :D
