Have a question? Ask Woody!
What Shear Scrapper to use
Bill Jacksonville, NC
To clean up inside my flower?
Re: What Shear Scrapper to use
Rob Wallace
Rob Wallace
A sharp Hunter tool carbide cutter, held at a steep shear angle should get rid of the tear-out. You could also try a small round-nosed scraper held in shear mode and take light cuts working from center-out.... just be careful as you approach the rim.
Don't use a flat scraper held horizontally - you'll keep getting the tear-out.
Rob
John lucas
This is the same as cleaning up the inside of a box. A round nose scraper is what I used to use. Now days I prefer to use the Hunter #5 or #4
robo hippy
It looks like you turned it end grain. A negative rake scraper will do a fine job in there, or I do use the fluteless gouges for that one as well.
robo hippy
Thank you for all the advice will give it a try. Hope will not go thru sides again.
don stephan
I've gotten to like a scraper with a bevel extending back along the left side, I think it might be called a swept back scraper? I noticed that Richard Raffan seemed to sharpen the end at 70 degrees and as he came back the left side increased the bevel to almost 90 degrees. That has helped me, as the steeper angle seems to be less aggressive on the side and to the rim.
